SRS indicator light is constantly on
does anybody know how to turn off the SRS indicator light off? i just recently installed a cd changer under my passenger seat. i disconnected 2 plugs that was connected underneath the seat. well, once i completed the job i connected all the plugs that i disconnected. everything works but the SRS light is on. can anybody help me with this problem? thanks!!!!
that's an airbag light have the dealer reset it if u can't do it manually. i.e. disconnect battery, or pull ecu fuse. i did that to my girls hyundai(please no flaming, i know the car sucks but it's hers.) anyway nothing worked until i took it to the dealer and they reset it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg_nezay »</TD></TR><TR><TD CLASS="quote">I had to do it once due to my seats I installed.
Here is how;
1st step in erasing the memory is to turn the ignition off and connect the SCS Service connector to the MES Plug,
2nd Turn Ignition on. SRS indicator light will come on for about 6 seconds then go off.
3rd Disconnect SCS service connector for MES connector within 4 seconds after SRS indicator light goes off. SRS indicator light will come on again.
4th Reconnect SCS service connector the MES connector within 4 seconds after SRS light comes on. SRS indicator light will go off.
5th Disconnect SCS service connector from MES connector within 4 seconds. SRS indicator light will indicate that memory is erased by blinking 2 times.
6th Turn ignition off, and wait 10 seconds. Start vehicle like normal and light should come on and go out like normal. You have reset your SRS light, congrats.
If it does not work the first time try it again, the timing has to be perfect. My first time it took me 3 attempts before it worked, but it did work.
BTW- like someone else said, if it just turned on out of the blue, you should go get it checked at the dealer.</TD></TR></TABLE>
The plug
Thanks to eg_nezay.
Here is how;
The plug
Thanks to eg_nezay.
what/where is this SCS service connector and what/where is this MES plug. is it that yellow connector? sorry im just having a hard time with this. if your referring to that yellow plug it was already plug in just like the your picture diagram. AHHHHHHHHH!!!!!!!
**** worked like a charm. my friend and i used a momentary button as the scs service connector. hey it work! just wanna say thanks you all for your help. very much appreicated!!!!!
-jeff P. (ro9ue18)
san diego
TNGO415
Dec 15, 2003 10:01 AM
