Throttle cable sticking
Old Aug 9, 2003 | 09:27 AM
snatch's Avatar
Default Throttle cable sticking
I swapped an EX manifold onto my 99 hatch awhile back, and I swapped in an EX throttle cable too. Now the throttle sticks, not all the time, but often when I come to a light and push in the clutch, it will just stick at 2500-3000, pretty much wherever the gas was. I tried adjusting the tension thinking maybe it was too tight, not helping. I don't have any other ideas. Any suggestions as to what could be the problem? Thanks.
Andy
Old Aug 16, 2003 | 12:51 PM
snatch's Avatar
Default Re: Throttle cable sticking (******)
anyone any ideas????
Old Aug 18, 2003 | 04:42 AM
cxSOHChatch's Avatar
try wd40 or some type of grease where the throttle cable enters through the firewall
Old Aug 18, 2003 | 06:37 AM
sohc_boy's Avatar
Default Re: (cxSOHChatch)
your t/b could also be sticking causing the same thing. just try and get some carb cleaner and clean out your t/b. i have the same thing happening to me i thought it was the cable so i replaced it and it still does it. so i'm gonna get some gum out and clean out the t/b.
Longhorn450
Apr 15, 2010 01:45 PM
19992civichatch
Jan 10, 2007 06:27 AM
rolledthatho
Sep 9, 2005 10:29 AM
