Z6 Valve Clearence question
Old Aug 9, 2003 | 08:11 AM
hondaless's Avatar
Default Z6 Valve Clearence question
What should the clearence be on a Z6 motor were doing a mini-me on my cousins del sol and he doesn't have a book for it. And also which is the right mark on the cam gear for TDC it has 3 marks on it which should be pointing up?
Old Aug 9, 2003 | 07:23 PM
crx304's Avatar
Default Re: Z6 Valve Clearence question (evilcrx)
intake .007 -.009
exhaust .009 - .011
on the cam gear, 2 marks are in line w/ each other, and one is 7:00. the 2 marks that are in line should be in line w/ the head surface, the 7:00 mark should point at the rear timing belt cover pointer, and "TOP" should be at top.
to find TDC put 2 straws together and insert into #1 cyl. rotate crank by hand until straw is at peak height. look at harmonic balancer. there are 2-3 lines and then there is one line that stands alone. the standalone line should be in line w/ the front timing gear cover pointer, if not adjust by hand. the straw method will insure that you are not 180 degrees off.
good luck
mike
Hankhall
Feb 5, 2010 12:11 PM
black0hatch
Aug 27, 2009 05:54 PM
HybridRacer69
Nov 9, 2007 03:10 PM
ci_v_ic
Jul 27, 2006 06:23 PM
Power Rev Racing
Aug 15, 2005 04:45 AM
