someone School me On civic brake master cylinders!!!!!
Guest
Posts: n/a
i've got a 94 civic si w/abs (god damn it) and the master cylinder is bad. i need a new one but if i can upgrade to integra that would be awsome! well, which one works??? can it be a gsr,rs,ls etc. etc as long as they had abs??? i don't want to bend any ******* lines or **** like that! will type r w/ abs work??? someone out there let me know. thanks in adavance.!!
the integra master cylinders only work with integra brake boosters from what i hear but should work fine otherwise if you get both
The whole bending lines is a bunch of crap. It is easy.
What size MC did your car have? Is it still a 15/16?
I have a lot of those for sale. PM me if interested.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG TYPE-R »</TD></TR><TR><TD CLASS="quote">the integra master cylinders only work with integra brake boosters from what i hear but should work fine otherwise if you get both
that's bullshit, i have an 00' ITR M/C on my 98 EK stock B/B...
*edit......go here and read https://honda-tech.com/zerothread?id=152884
if you have abs on your car changing the master cylinder from one type to another will not upgrade it. the abs will only allow a certain amount of braking force to occur. thats what abs is for. buy the parts that are made for your car.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by realblag »</TD></TR><TR><TD CLASS="quote">if you have abs on your car changing the master cylinder from one type to another will not upgrade it. the abs will only allow a certain amount of braking force to occur. thats what abs is for. buy the parts that are made for your car.
well, i did, but i wanted to maybe upgrade so this was the whole point on the thread! so
to u!
</TD></TR></TABLE>well, i did, but i wanted to maybe upgrade so this was the whole point on the thread! so
to u!
If you want to do away with your abs then a non-abs teg master cylinder will do more than a stock non-abs master. If you change the master to something else but leave the abs in place then you have gained nothing but the rights to say " I got a teg master cylinder" because the abs unit will regulate the braking force to the same specs. as what you have now.
markH22eg6
Jan 8, 2009 07:10 AM
lol
