What do you do to keep your turbine housing free of rust?
Old Aug 8, 2003 | 11:42 AM
Kwuaymaikrup's Avatar
Default What do you do to keep your turbine housing free of rust?
I am looking into a temp coating of some sort but the companies around here want way to much $$...just looking for alternatives. Thanks,
-Ryan
Old Aug 8, 2003 | 12:08 PM
TeStUdO's Avatar
VHT paint wont do it, ill think youre gonna have to look into jet hot or some other coating
Old Aug 8, 2003 | 12:25 PM
BROOD's Avatar
Default Re: (TeStUdO)
Jet-Hot, Swain, etc. Some sort of high temp ceramic coating.
Old Aug 8, 2003 | 12:39 PM
boosted92's Avatar
Default Re: (SLPR)
Swain coatings
Old Aug 8, 2003 | 12:51 PM
BodyKits NW's Avatar
Default Re: (boosted92)
How hard is to disassemble it for coating?
Old Aug 8, 2003 | 04:56 PM
BROOD's Avatar
Default Re: (BodyKits NW)
Not difficult at all, a few bolts to remove then ship the turbine housing to the coater.
Plus the coater will do the clean-up and prep themselves (it is included in the cost)
Old Aug 8, 2003 | 05:07 PM
MotorMatrix.com's Avatar
I am a bad person
Default Re: (SLPR)
jet hot coat it. i paid 85.00 for the inside and out to be coated locally.
Old Aug 8, 2003 | 06:39 PM
rtz's Avatar
rtz
One more option: http://www.airborncoatings.com/
Old Aug 8, 2003 | 06:52 PM
Default Re: (rtz)
They said I had to take the damn wheel out and stuff. So I don't have to do that? Give me some insight. I'm a dumbass when it comes to turbo's lol.
Old Aug 8, 2003 | 06:56 PM
Farnsrocket's Avatar
Undo the center housing bolts on both sides and the exhaust and compressor sides will pull off............just take them off carefully and watch the fins.
Old Aug 8, 2003 | 06:58 PM
alpha's Avatar
No. The turbine housing will come off with ease.
Old Aug 8, 2003 | 07:28 PM
Default Re: (0x64)
Thanks guys! That was easy enough. I thought it would be a lot more complex than that. Those are the same bolts I had to loosen when I had to rotate the housing.
Old Aug 8, 2003 | 08:12 PM
I am a bad person
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BodyKits NW &raquo;</TD></TR><TR><TD CLASS="quote">Thanks guys! That was easy enough. I thought it would be a lot more complex than that. Those are the same bolts I had to loosen when I had to rotate the housing. </TD></TR></TABLE>
exactly.
Old Aug 9, 2003 | 11:41 AM
lazerus's Avatar
Default Re: (MotorMatrix.com)
if you're a cheap bastard like me, and cant afford to even pay 85 dollars to coat it. get a can of copper spray, and coat the turbine housing with it. once heated up for the first time, the copper turns a cast iron grey color. i always use it if the turbine housing is not coated otherwise.
Old Aug 9, 2003 | 02:12 PM
*Boostwerks*'s Avatar
Default Re: What do you do to keep your turbine housing free of rust? (Kwuaymaikrup)
I've coated mine with several coats of silicon exhaust spray (summit retails it).
I used the same stuff on my old turbo and manifold, and it looked great even after a year of daily driving.
Heres what my new setup looks like...
Old Aug 9, 2003 | 02:24 PM
PWRVTEC's Avatar
I find that if it does not get wet, that putting a light coat of WD 40 or Liquid Wench on it now and again keeps it looking like cast iron...
The down side is it smells for a few mins after start up.
But it seems to kepp mine rust free...
Old Aug 9, 2003 | 02:46 PM
Default Re: What do you do to keep your turbine housing free of rust? (Bryson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryson &raquo;</TD></TR><TR><TD CLASS="quote">I've coated mine with several coats of silicon exhaust spray (summit retails it).
That looks really good Also seems to be the easiest and cheapest way. I think I will do this. Thanks!
-Ryan
Old Aug 9, 2003 | 02:54 PM
saso
Guest
Posts: n/a
Motor matrix what is that front the Oem front cover over those cams gears? Damn i dont even have one of those. I want one.
Old Aug 9, 2003 | 10:30 PM
I am a bad person
Default Re: (saso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by saso &raquo;</TD></TR><TR><TD CLASS="quote">Motor matrix what is that front the Oem front cover over those cams gears? Damn i dont even have one of those. I want one.</TD></TR></TABLE>
its the stock valve cover uncut. maybe it looks weird cause the motor isnt dressed out yet with all the accessories.
nico.tico
Nov 19, 2010 05:17 PM
ID_ten_T
Aug 30, 2004 08:41 PM
Just Checking In
Apr 13, 2004 05:07 PM
zojirushi
Dec 2, 2002 08:54 AM
DigitalFusion
Jun 19, 2002 06:06 PM
