Q's about LS/Vtec build up *already searched*
Old Aug 8, 2003 | 11:29 AM
hatchdrvr's Avatar
Default Q's about LS/Vtec build up *already searched*
I am in the process of gathering a parts list for my LS/Vtec and have a couple of questions.
here is the proposed setup
LS block (obviously)
LS crank and rods
CTR or ITR pistons and rings
b16 head (ITR cams and valve springs/titanium retainers)
new Honda bearings
new itr oil pump and water pump
vtec timing belt
LS head gasket
ok so here's the Q's
1. will there be a problem with piston to valve clearance with the ITR/CTR
pistons on the LS rods and the ITR cams?
2. who makes the best all inclusive LS/Vtec oil line kit? Endyn?
3. what kind of compression #'s would I be looking at
4. my goal is 200whp N/A, is it possible with this setup?
That's all for now, Thanks guys for any help, I've done plenty of mechanic work before on my car but I've never built a motor before.
Old Aug 8, 2003 | 12:51 PM
RaIn's Avatar
Not with that setup can you hit 200whp stock, but it easily has the potential. I had ls/vtec loved it. I would go with b16a2 pistons though, they have a higher comp then ITR pistons, and use a GSR head, and mill it like .010. That should give you around 12.1 compression. CTR pistons will be too high compression for the street unless you have hondata and a good tuner.
Other option is to get itr pistons and gsr head, and mill the head more to get the compression, bc ITR pistons have a heat coat on the sidewalls of the pistons to cool the temp down, which helps. (The CTR's also have the heat resisting coat on them)
IslandStyle
29
Mar 26, 2010 08:15 PM
lscoupe
Feb 18, 2005 04:24 AM
hatchdrvr
Aug 8, 2003 04:17 PM
hatchdrvr
Aug 8, 2003 04:08 PM
hatchdrvr
Aug 8, 2003 01:03 PM
