can i run a N/A cam on a turbo'd car?
Old Aug 7, 2003 | 11:44 PM
SPOON_BeIgHtEeNsEe's Avatar
Default can i run a N/A cam on a turbo'd car?
im looking to buy a crower cam for my y8 but its for a N/A car... i was woundering if i would gain or lose power if i ran this cam in my car and if its a good idea to run it on a FI car???... i have a d16y8 with turbo... the cam is a crower stage 2 63442...
Old Aug 8, 2003 | 12:10 AM
Default Re: can i run a N/A cam on a turbo'd car? (SPOON_BeIgHtEeNsEe)
16 views and nothing
Old Aug 8, 2003 | 09:24 AM
no one>?
Old Aug 8, 2003 | 09:25 AM
boosted92's Avatar
Not worth it. Turbos don't like a ton of overlap, and most N/A cams have a ton of it. You will probably make more power by just sticking to your stock cam.
Old Aug 8, 2003 | 10:54 AM
94TurboGSR's Avatar
You can do it, but as said previously the overlap will hurt your performance. You'd be very lucky to keep what power you have; more than likely you'll lose power.
Old Aug 8, 2003 | 11:03 AM
skribblah's Avatar
Default Re: can i run a N/A cam on a turbo'd car? (TealTurbo)
IN MY OPINION!
stock GSR cams = best for turbo
Old Aug 8, 2003 | 11:11 AM
twkdCD595's Avatar
Default Re: can i run a N/A cam on a turbo'd car? (skribblah)
stock n/a cams are usually pretty conservative on overlap and cam gears can dial in the rest.
Old Aug 8, 2003 | 11:13 AM
boosted92's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skribblah &raquo;</TD></TR><TR><TD CLASS="quote">IN MY OPINION!
stock GSR cams = best for turbo</TD></TR></TABLE>
That's nice but he has a D16
Old Aug 8, 2003 | 11:19 AM
Default Re: can i run a N/A cam on a turbo'd car? (boosted92)
hehe yea i have a d16... but thanks for all ur help... ill just stick with my y8 cam...
Old Aug 8, 2003 | 07:20 PM
skribblah's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted92 &raquo;</TD></TR><TR><TD CLASS="quote">
That's nice but he has a D16 </TD></TR></TABLE>
then id use the JDM D15B cam.
Old Aug 9, 2003 | 01:45 PM
TravSi's Avatar
i have the zex 59300 cam and it works great for my car with boost.....higher lift than the crower turbo cam and less duration than it too...almost as if zex designed it for FI setup...i dyno'd 205whp so somethin worked out good.....boost and the top end of that cam work great together i think.....just a suggestion
Trav
Old Aug 9, 2003 | 01:52 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: can i run a N/A cam on a turbo'd car? (RexSiT3)
I personally believe stock cams are best for turbo, unless the cams are specified down to the "T" for your complete setup. That just my opinion.
Old Aug 9, 2003 | 01:53 PM
ATS*Mark's Avatar
OG triple OG
if you want a cam for a turbo car , buy a turbo camp
Old Aug 9, 2003 | 09:11 PM
TurboJesse
Guest
Posts: n/a
Default Re: can i run a N/A cam on a turbo'd car? (TURSpoonEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TURSpoonEK &raquo;</TD></TR><TR><TD CLASS="quote">if you want a cam for a turbo car , buy a turbo camp </TD></TR></TABLE>
I wish my mom sent me to turbo camp when i was little
Old Jan 27, 2004 | 07:19 PM
Naterror's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted92 &raquo;</TD></TR><TR><TD CLASS="quote">Not worth it. Turbos don't like a ton of overlap, and most N/A cams have a ton of it. You will probably make more power by just sticking to your stock cam.</TD></TR></TABLE>
Thats true boost doesn't like a lot of over lap, but I disagree about NA cams not being worth it. I have Skunk stage 2 cams that are going to be used with my boosted motor. The difference is I'm using cam gears to dial out most of the over lap.
If you still think its useless then read the January issuse of HCI on the 650hp Boosted motor build up.
92_civic_eg
Jan 23, 2018 04:07 AM
da_all_day
May 29, 2011 09:45 AM
SnekyDevilz
Apr 26, 2010 09:09 PM
roddy9
Jan 8, 2008 08:54 PM
NA JDM GSR
Oct 29, 2006 10:44 AM
