VX injectors....240CC??
I did a B18B OBD2 swap in my VX...
someone told me that I had to swap the B18B injectors for OBD1 injectors....
1-true?
2-Can I put the VX injct??...same as D15/D16/B18 injct(240CC)??
tanx
1-true?
tanx
I THINK they may be like the CX injectors, 180cc. You should be able to use them for a stock b18b setup, but when you start modding it add bigger injectors.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lowexr »</TD></TR><TR><TD CLASS="quote">I guess I have to put the same injct size from the B18B OBD2.....</TD></TR></TABLE>YOU CAN RUN THE VX INJECTORS WITH LITTLE TO NO MODS TO YOUR ENGINE! User Chad has done it several times on B16a swaps.
what car are you putting this motor into... what harness are you using.. if its an obd2 teg engine goin in a obd1 civic then its plug and play with all the teg stuff as long as you have obd2 ecu... if its goin into obd2 civic why change em?
todds94teg
Jun 24, 2002 12:32 PM
