VX injectors....240CC??
I did a B18B OBD2 swap in my VX...
someone told me that I had to swap the B18B injectors for OBD1 injectors....
1-true?
2-Can I put the VX injct??...same as D15/D16/B18 injct(240CC)??
tanx
1-true?
tanx
Re: VX injectors....240CC?? (lowexr)
I THINK they may be like the CX injectors, 180cc. You should be able to use them for a stock b18b setup, but when you start modding it add bigger injectors.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lowexr »</TD></TR><TR><TD CLASS="quote">I guess I have to put the same injct size from the B18B OBD2.....</TD></TR></TABLE>YOU CAN RUN THE VX INJECTORS WITH LITTLE TO NO MODS TO YOUR ENGINE! User Chad has done it several times on B16a swaps.
official honda whore
what car are you putting this motor into... what harness are you using.. if its an obd2 teg engine goin in a obd1 civic then its plug and play with all the teg stuff as long as you have obd2 ecu... if its goin into obd2 civic why change em?
Re: (coptzer)
92 civic VX---->B18B1 97 OBD2...
I'M using the OBD1 P06 ecu(from a civic DX)....
should I keep my B18B1 injectors....or use a OBD1 injectors..same size?
todds94teg
06-24-2002 12:32 PM
