rebuilt engine how should i keep it lubed while its sitting
can someone tell me what i should spray/put in the engine while its waiting to be installed. It has been freshly rebuilt and i don't want to chance anything when i put it in. thanks guys
just keep oil in it, and turn it over clockwise with a 19mm wrench on the crank pulley bolt every day/other day or so. this will make the oil pump pump oil through the orifices, and keep everything good and lubed up.
also, you might want to throw in a quart of lucas oil before you do this the first time, as it sticks on everything it touches for a long time. good stuff
i used it as assembly lube when i built my motor.
way to take care of jOOr shiz mang
i used it as assembly lube when i built my motor.way to take care of jOOr shiz mang
951dc5
Mar 4, 2007 06:34 PM
JD_B18CDX
Nov 28, 2002 12:15 PM
d0nkeyxPunch
Jan 6, 2002 11:53 PM
