where did my compression go?
Old Aug 7, 2003 | 04:52 PM
SprayinCX's Avatar
Default where did my compression go?
okay the other day one of my coolant hoses came off. and i turned the car off immediatley. after it cooled off and we refilled it with water,fixed the hose leak, and checked the oil level. it didn't crank!
so here is a list off all the stuff we have already done:
checked timing
checked for spark
checked for fuel (the injectors are spraying)
checked headgasket
checked intake manifold for clogs
checked all wiring harness conections
all we came up with was bad compression
it went like this 70-60-70-75
we did that before removing the head to find out the gasket was still good. So do you have any idea on where it might be? the compression that is.
Old Aug 7, 2003 | 04:59 PM
yobtah's Avatar
Default Re: where did my compression go? (SprayinCX)
Does the car run differently than it did before this happened? If not (and you have a high-mileage or abused engine), you might have had low compression before and you simply didn't know it. If, on the other hand, compression was good before, you probably warped (or possibly cracked) the head.
Old Aug 7, 2003 | 05:04 PM
SprayinCX's Avatar
Default Re: where did my compression go? (yobtah)
i had the motor competly redone with new gaskets and everything.
as of right know the car doesn't even crank! at all..........it won't catch fire.
Old Aug 7, 2003 | 06:28 PM
SprayinCX's Avatar
ttt as i go to work
Old Aug 7, 2003 | 06:55 PM
viprcr1's Avatar
well you do need compression to run an engine.
Old Aug 7, 2003 | 07:09 PM
EARLdaSQUIRREL's Avatar
official honda whore
thats really odd... my friend doesnt have compression but his timing belt broke... you sure your timing belt hasnt broke?
Old Aug 7, 2003 | 08:07 PM
Dancing is Forbidden's Avatar
Bad rings, bad head gasket, bad valves? Weird!
Old Aug 7, 2003 | 08:38 PM
94hondaLS's Avatar
Default Re: where did my compression go? (viprcr1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by viprcr1 &raquo;</TD></TR><TR><TD CLASS="quote">well you do need compression to run an engine.</TD></TR></TABLE>YES
Old Aug 8, 2003 | 01:22 AM
LSVTECoupe's Avatar
how the hell did u get those numbers if the car doesn't even crank over? doesn't the car have to crank in order to show psi on the gauge?
Old Aug 8, 2003 | 02:29 AM
DCStreetHtch's Avatar
Default Re: (LSVTECoupe)
hand crank
-Bryan-
Old Aug 8, 2003 | 03:50 AM
SprayinCX's Avatar
Default Re: (EGStreetHtch)
the car wiil turn over but it will not start.
no........ the timing belt was replaced about a week ago.
i am going to check to see if the head is wrapped today
Old Aug 8, 2003 | 05:03 PM
GSRswapandslow
Guest
Posts: n/a
Default Re: (SprayinCX)
i have no idea what that could be.
TTT for you
Old Aug 8, 2003 | 06:49 PM
NonovUrbizniz's Avatar
Loved
check ALL your fuses... mainly the ones under the hood but I'd check'em all just to be sure...
you could've shorted something out by accident while working on it.
Old Aug 9, 2003 | 03:45 PM
SprayinCX's Avatar
Default Re: where did my compression go? (NonovUrbizniz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NonovUrbizniz &raquo;</TD></TR><TR><TD CLASS="quote">check ALL your fuses... mainly the ones under the hood but I'd check'em all just to be sure...
you could've shorted something out by accident while working on it.</TD></TR></TABLE>
did that also i forgot to mention that
wayneDOHC
Aug 20, 2013 11:58 AM
Nicolai
Jun 16, 2013 03:38 PM
97itr86
Oct 30, 2004 08:51 AM
Ri5e
Feb 10, 2002 09:54 AM
GSR44
Jan 11, 2002 09:58 AM
