skunk2 stage 1's or ITR/CTR cams
Old Aug 7, 2003 | 12:48 PM
importboi22's Avatar
Default skunk2 stage 1's or ITR/CTR cams
what makes more power on a Stock ITR motor with i/h/e a good exhaust setup jdm dc4-1 / test pipe/ skunk2 exhuast.... how about on a mildly done b20/vtec with 10.5:1 compression..... just curious cuz some people said that the skunk2 stg1's dont make more power than the ITR/CTR cams... true or false?
Old Aug 7, 2003 | 12:50 PM
el arbi's Avatar
Default Re: skunk2 stage 1's or ITR/CTR cams (importboi22)
go with the Skunk2 Stage 1's , much better.
Old Aug 7, 2003 | 12:53 PM
Rob :190:'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importboi22 &raquo;</TD></TR><TR><TD CLASS="quote">just curious cuz some people said that the skunk2 stg1's dont make more power than the ITR/CTR cams... true or false?</TD></TR></TABLE>
dont believe everything people tell you. The SKunks should make more power than the OEM cams on either setup.
Old Aug 7, 2003 | 01:49 PM
patdemps's Avatar
Default Re: skunk2 stage 1's or ITR/CTR cams (Rob :190:)
I've heard from 3-5 more whp from the Skunk2 Stage one cam's. Thats not that great of a difference when you consider the pricing differences. Id go with ITR/CTR (oem quality). There is quite a price gap between the 2 for not that much difference. It depends what kind of power band you are after too. Skunk2 would be more power way up top and the itr/ctr cams have a good mid and top range setup. Also, I think the skunk2's have a longer duration then the itr/ctr cams.
I say go with ctr/itr cams. Unless you want to spend a chunk more of money for a maybe just a bit more power. And you never know with your setup one cam may respond better then the other.
Old Aug 7, 2003 | 01:50 PM
patdemps's Avatar
Default Re: skunk2 stage 1's or ITR/CTR cams (patdemps)
If your real serious about racing it then the skunk2's are better for top end power. ITR/CTR aren't too far behind but they have better midrange power. I say a ctr/itr cam is a great cam for the street , also for the track but the skunk2's perform a little bit better up top and are capable of pushing out more power if you want to change your redline. it all depends what kind of goals you are searching for and what kind of powerband you have.
Old Aug 7, 2003 | 02:04 PM
92TypeR's Avatar
FSAE
CTR cams will provide you with more usable power, especially after a nice day of tuning on the dyno
Skunk2 Stage 1's are a good alternative, and you will have a higher peak power (in horsepower and RPM wise).
Also consider the Jun2 intake cam along with the ITR exhaust cam. Extremely good low-mid range with a nice topend.
Old Aug 7, 2003 | 02:25 PM
Rob :190:'s Avatar
Default Re: skunk2 stage 1's or ITR/CTR cams (92TypeR)
Its my understanding that the SK Stg 1s mimic the ITR power band, but with a higher hp/tq level.
either way you go, make sure you get it tuned!
Old Aug 7, 2003 | 02:52 PM
Misfit's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rob :190: &raquo;</TD></TR><TR><TD CLASS="quote">Its my understanding that the SK Stg 1s mimic the ITR power band, but with a higher hp/tq level.
either way you go, make sure you get it tuned!</TD></TR></TABLE>
I have heard the same thing.
Old Aug 7, 2003 | 04:00 PM
freakifran's Avatar
If you are interested in type r cams i have 2 sets 4 sale.
00 JDM typeR cams used-350.00
00 USDM typeR cams still in box(shipped)-495.00
Im using the skunk stage1 cams right now in my typeR motor and they definitly make more power, 200whp with only intake,exhaust, and computer.
Old Aug 7, 2003 | 04:02 PM
freakifran's Avatar
they definitly need to be tuned though, if your intrested in any of the typeR cams email me
lawqt0205@aol.com
dc4teg95
Jan 24, 2007 02:36 PM
spikerockz
Jun 8, 2006 07:42 AM
Fresno_NSX
Mar 28, 2005 01:24 PM
Mentat Ghola
29
Jun 19, 2003 06:11 PM
1.7na
Oct 4, 2002 11:09 PM
