My valves are tapping when i turn on the car for the first time of the day
Old Aug 7, 2003 | 12:24 PM
1998accordlx's Avatar
Default My valves are tapping when i turn on the car for the first time of the day
i have heard my valves tapping when i turn on my engine early in the morings or when ever i turn it on for the first time of that day and when the car starts warming up it gets a little better but it doesn't stop completely could it be from my spark plugs????? BY the way i have a 1998 accord LX 2.3 VTEC 4cyl
Old Aug 7, 2003 | 01:01 PM
YeuEmMaiMai's Avatar
time for valve adjustment
Old Aug 7, 2003 | 01:49 PM
NAR Cd7 Lude
Guest
Posts: n/a
Default Re: My valves are tapping when i turn on the car for the first time of the day (1998accordlx)
When your driving your car, does it sound somewhat of a ticking? Not so much of knocking, but a ticking sound. My car tends to do the same thing. When the temp is cold outside, the ticking is a bit louder.
I went to get a valve adjustment to see if the problem would stop, but the thing is, is that i had gotten a valve adjustment 6 months prior to the problem. My mechanic looked into the problem more, and it turns out that its the Lost Motion Assembly.
Hope the info helped a little.
Old Aug 7, 2003 | 10:16 PM
Default Re: My valves are tapping when i turn on the car for the first time of the day (NAR Cd7 Lude)
see when the engine get's warm it's good it's not that loud when the rpm goes up more than1500 it stops making that nois it does it only in 1500 RPM
Old Aug 8, 2003 | 03:06 PM
RotaryBzzzz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAR Cd7 Lude &raquo;</TD></TR><TR><TD CLASS="quote">the Lost Motion Assembly. </TD></TR></TABLE>
How much did he quote for that?
Old Aug 8, 2003 | 04:41 PM
The Maryland Truth's Avatar
could be vavle adjustment or low oil . Nope it's not the plugs
Old Aug 8, 2003 | 09:21 PM
SIMATIC's Avatar
Default Re: My valves are tapping when i turn on the car for the first time of the day (The Maryland Truth)
yea check ur oil, my friends mitsubishi was making a knockin noise... i pulled out his dip stick and the oil was baked onto the stick and no oil in the engine. You hadda see this knocking stop after he added oil. the damage was done anyway ! good luck
98 accord...5 speeds are sometimes not enough
Old Aug 10, 2003 | 03:21 AM
NAR Cd7 Lude
Guest
Posts: n/a
Default Re: My valves are tapping when i turn on the car for the first time of the day (RotaryBzzzz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RotaryBzzzz &raquo;</TD></TR><TR><TD CLASS="quote">
How much did he quote for that? </TD></TR></TABLE>
i remember him quoting me 3 bills...
Old Aug 10, 2003 | 03:42 AM
NAR Cd7 Lude
Guest
Posts: n/a
Default Re: My valves are tapping when i turn on the car for the first time of the day (SIMATIC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIMATIC &raquo;</TD></TR><TR><TD CLASS="quote">yea check ur oil, my friends mitsubishi was making a knockin noise... i pulled out his dip stick and the oil was baked onto the stick and no oil in the engine. You hadda see this knocking stop after he added oil. the damage was done anyway ! good luck
98 accord...5 speeds are sometimes not enough </TD></TR></TABLE>
For the knocking... you can also try to use higher octane, such as race gas.. which is $$$, or just use an octane booster. if the knocking goes away, then , if not then, could be that you need a valve adjustment.
as for the low oil... i dont think the knocking could be from that... if there was no oil and you ran your car like that... then the motor would blow...
he also told me that the prob could be that the consistency of the oil is too thick, which is causing the valve lifter to not operate at the normal speed. in other words, the thickness of the oil slows the lifters down. the oil im using is 10W-30... he sugguested that i use 5W-30
Old Aug 10, 2003 | 08:37 AM
according to the honda charts all 1994 and newer accords are supposed to use 5w30 or thinner (newer models) no wonder your car sounds like a sewing machine......
Old Aug 10, 2003 | 10:30 PM
Excelerate's Avatar
Default Re: (YeuEmMaiMai)
what if you put a turbo on your car... i thought they recommended thicker oil? something like 20/50 any ideas?
Old Aug 11, 2003 | 12:54 AM
NAR Cd7 Lude
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai &raquo;</TD></TR><TR><TD CLASS="quote">according to the honda charts all 1994 and newer accords are supposed to use 5w30 or thinner (newer models) no wonder your car sounds like a sewing machine......</TD></TR></TABLE>
well my motor isnt stock
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JPLockwood &raquo;</TD></TR><TR><TD CLASS="quote">what if you put a turbo on your car... i thought they recommended thicker oil? something like 20/50 any ideas?</TD></TR></TABLE>
yes, if you have turbo, you are supposed to use thicker oil. i'd say 15/50... but not sure...
Old Sep 21, 2003 | 10:07 AM
turboxsi's Avatar
Default Re: (NAR Cd7 Lude)
i would get your lost motion assembly checked
Old Sep 21, 2003 | 01:37 PM
NathanMorris's Avatar
Default Re: (turboxsi)
accords are known for notoriously loud rocker arms and valves.....unless it's a lot louder than it used to be, I wouldn't be tooooo worried about. Just make sure your oil level is good as mentioned, and if you have more than 40,000 miles on the car and havn't had a valve adjustment....get one.
- Nathan
jmai86
Apr 1, 2008 12:10 PM
Peruviann83
Mar 30, 2007 10:10 AM
wragen22
Apr 8, 2005 11:44 AM
davidnguyen
Nov 8, 2004 08:09 PM
lilxvtecxpwr
11
Sep 17, 2002 05:58 PM
