Need help bad....
Old Aug 9, 2001 | 07:46 AM
hybrid_KJ's Avatar
Default Need help bad....
Working on a friend of mines car, he blew his cx motor and I'm trying to help him out by installing a dx.
Car is a cx, motor is a 92 dx. I used the cx harness. The 92 dx motor does not have a map sensor located on the throttle body. I guess 92's located them on the firewall? So I used the cx one and ran a hose from the map to the throttle body. Next problem was the eacv, it was missing from the dx motor so I used the one from the cx. The bolts did not line up w/ the manifold. I used one bolt and gasket sealant and the ports lined up.
Now the car starts up and idles bad. At about three grand it breaks up and falls flat. The only code I'm getting is a 41, which is oxygen sensor heater...which was expected. I've been trying to troubleshoot this thing but I've had no luck. I don't have a spare dx map sensor or eacv laying around, would the cx ones be causing the problem? If anyone has any ideas or suggestions the help would be greatly appreciated.
Thanks
Kevin
Old Aug 9, 2001 | 07:54 AM
rainforest's Avatar
Default Re: Need help bad.... (hybrid_KJ)
your car is running in limp mode dying a 3k rpm's.did you try reseting the ECU.if you nly have a 41 then you sould not have a problem with the map or eac valve.
greenhorn civic
Sep 19, 2017 06:03 PM
WhiteOnRice
10
Oct 17, 2009 07:47 AM
BadFD
Sep 4, 2008 07:51 PM
PointA2B
23
Mar 2, 2007 10:07 AM
tyronebiggums
18
Apr 1, 2003 08:41 PM
