How 2 take off STUCK wheel?
I was trying to put on 00 Si wheels on my brother's 92-cx , but the damn wheel is stuck on for good and try to kick it off everyway and its all 4 wheels....anyone experience this prolem before and what can I do about it?....thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fowleryo »</TD></TR><TR><TD CLASS="quote">kick harder</TD></TR></TABLE>
Kick that bitch! It will come off!
It has sorta rusted against your hub. My advice would be to kick harder like others said, but only if you car is properly supported. A good kick can throw a car off balance and it may come crashing down.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 point 6 »</TD></TR><TR><TD CLASS="quote">You take off the lug nuts yet??</TD></TR></TABLE>
probably not.
if the luts are out you should be able to take it off with a tap.
probably not.
either kick or get a big rubber mallet or use your hand if you're hardcore and hit it from the back side.
Kicking from the front will work if they are just on there tight, but if its on there REALLY tight the backside works best.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acuracing »</TD></TR><TR><TD CLASS="quote">It has sorta rusted against your hub. My advice would be to kick harder like others said, but only if you car is properly supported. A good kick can throw a car off balance and it may come crashing down.</TD></TR></TABLE>
like he said, before you start kicking the **** out of the tire, make sure the car is supported.
2.2L EH2
24
Mar 19, 2022 03:40 PM
Razr2
28
Jun 5, 2008 10:52 PM
mikeunreal2
Apr 16, 2006 02:55 AM
