Obd 0 - OBD1 conversion, is this right? ( please help)
Alright im converting my CRX to OBD1 . Im also using an OBD 1 LS b18a. Here is the list of things i need, is here anything eles e or do i have it all?
OBD1 ECU
coversion harness OBD0- OBD1
OBD1 injectors and plugs
OBD1 distributor
get rid of my injector rersistor box and splice all 5 wires togheter.
Does thgis sound right??..........
Did i miss anything?
OBD1 ECU
OBD1 distributor
You do not have to run the OBD1 injectors. That is your decision. If you decide you want to run them, just solder the 5 wires together. For my conversion harness, you will also need a 4 wire O2 sensor.
More info and pics of my harness = click here
OK the 4 wire o2 , im guessing i just run the four wires to theyre apporpriate location?
Well unfortunalt i dont have an obd1 ls yet , im almost there ....
You will need to use your CRX harness on the OBD1 engine. This will allow you to use the plugs in your engine bay. You will have to modify the distributer plugs. The wire colors are the same in each harness, so just cut and solder the OBD1 dizzy plugs on. Also you will need to take the fuel injector plugs and corresponding wires off of the OBD0 harness and splice the OBD1 fuel injector wires in.
