problems
My car was acting wierd.When i went to check on my spark plugs two ports were clean and the other two had some oil in them.Im not sure what to do now.The car is fine now but i should really get that checked out so im going to get a check up done.What do you guys think?.The car is a 1994 civic dx auto(d15b7).
Your description is quite vague and I don't know what "acting wierd" means, but if you mean oil on the outsides of the spark plugs, above the threads, that's an indication of the O-ring seals under the valve cover leaking.
just bad gaskets. nothing major. i recomend getting all new valvecover gaskets and dont be shy with the honda bond
Modified by allmtr y0! at 4:31 PM 8/6/2003
smercer
Feb 9, 2005 10:12 AM
