Anybody have a coil go bad in a 92 civic VX?
Old Aug 6, 2003 | 11:51 AM
whoobeedoobee's Avatar
Default Anybody have a coil go bad in a 92 civic VX?
I am trying to narrow down possible reasons why I can't get a spark out of my spark plug wires other than the rotor button.
Someone told me that it could be the reason my car had a sputtering at low RPMs.
Thanks
Old Aug 6, 2003 | 05:02 PM
Default Re: Anybody have a coil go bad in a 92 civic VX? (whoobeedoobee)
What no posts?
I can't believe that no one has had a ignition coil go bad on a honda civic.
If anyone wants to know how, I just did it.
In a 92 Civic VX, it is actually inside the distributor. The coil cost about $80. If your spark plug wires will not produce a spark, a bad ignition coil could be the problem. All you have to do is:
1. Remove the dizzy cap (3 8mm bolts)
2. remove the rotor button (1 screw)
3. remove additional cover (pops right off)
Now you can see the coil. It has a spring sticking out of it.
4. You remove this by unscrewing 2 screws and 2 wires. This may go with out saying, but remember which wire is on top. On mine, and probably yours too, the black wire/ ground was on the bottom.
Insert new coil and reverse previous directions. This is a pretty easy DIY! While I was inside the dizzy, I replaced the rotor button. It cost me $20 from the dealer. I figured it was like insurance for the future.
Tools required:
8mm socket / wrench
Philips head screw driver.
atmospheric SOUL
Mar 11, 2009 08:51 AM
ianae86
12
Apr 12, 2006 06:05 PM
TehMan
Feb 17, 2006 11:18 AM
madcrossover
Sep 28, 2004 08:09 AM
Yambor
Jul 30, 2004 06:55 AM
