help with place racing front crossmemember
am i just dumb or what? how does the mount connect to the crossmember?
i have had my crossmember installed for about a month now, i just never put on the mount b/c i didnt know how it connected or if it would even work w/ my old style hasports.
anybody that has installed this pleas let me know
ohh and just to let you know, you cant tell from that picture, but there is actually a metal piece that connects those bars that come out of the center of the crossmember
What radiator are you going to use? Im not using that mount that connects to the front of the tranny. You dont really need and my car is a full drag car. 89civichatch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NA_crix »</TD></TR><TR><TD CLASS="quote">the crossmember should have come with two brackets that attatch to the two things comin off the crossmember and then angle up to attatch to the mount....kinda hard to explain/picture</TD></TR></TABLE>
hrmm... i didnt get any other brackets... and i hear afterhourz (where i bought it from) has closed down. Should i contact Place Racing directly to get these brackets?
and i have already installed a 53mm koyo 92-95 civic radiator. i know i dont need it, but if i got teh mount, i may as well use it
I am not sure if the front mount will work on your ride since you have Hasport mounts and they place the engine further back in the engine bay. Place Racing mounts place the motor further up...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90civichbsi »</TD></TR><TR><TD CLASS="quote">am i just dumb or what? how does the mount connect to the crossmember?
ohh and just to let you know, you cant tell from that picture, but there is actually a metal piece that connects those bars that come out of the center of the crossmember</TD></TR></TABLE>
seems like that picture is missing some pieces to it...
is it me or is that kit missing pieces?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NA_crix »</TD></TR><TR><TD CLASS="quote">yea, i'd give place race a call and see what they have to say....</TD></TR></TABLE>
they will say to buy Place Racing mounts....
There should have been two flat plate "brackets" that came with the cross-member. When I got mine, Place didn't put them in the box and I had to call them. They didn't give me any problem and just sent them to me. (who ever put the package together didn't know what he was doing!)
If you are using Hasport mounts you will have to modify the brackets or make up new ones due to the engine placement being different. On the assumption that the difference in engine placement is only front to back and up / down it should be real easy to make up new plates. If there is a difference in placement side to side then the brackets would have to have bends in them or spacers made up.
Wes Vann
Wes Vann
I have the same crossmember but i purchased mine used, with a 92-95 place racing radiator. I also have place racing mounts, but they didnt come with a front mount or brackets for the xmember and front mount.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF_LSVtec »</TD></TR><TR><TD CLASS="quote">Wex V is correct...they will not line up if you're using Hasport mounts. </TD></TR></TABLE>
yeah i knew that much, once i get them ill see how i need to modify them to fit, and take a stab at it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vap133 »</TD></TR><TR><TD CLASS="quote">I am not sure if the front mount will work on your ride since you have Hasport mounts and they place the engine further back in the engine bay. Place Racing mounts place the motor further up...</TD></TR></TABLE>
Hence my response....
jthelman
Jan 19, 2004 06:20 PM
hoya_10fintec
Oct 3, 2002 06:59 PM
