ghetto leakdown test idea>>
Old Aug 6, 2003 | 07:21 AM
platinum00's Avatar
Default ghetto leakdown test idea>>
will this work..
just do a compression check, get it to a certain psi (100) and let it sit and see if the number goes down.
is there a reason why this would not work. i know if i did have a problem it would not tell me where the problem is , such as my rings or my valve seels , but it would tell me if i had a problem. right..
thanks
platinum.
Old Aug 6, 2003 | 08:42 AM
aw1234dude's Avatar
Default Re: ghetto leakdown test idea>> (platinum00)
I don't know about yours but my compression tester holds the highest number on the gauge until you press the release button. I dunno maybe you have a different comp tester though.
Evs-One's Avatar
Solbros Owns Me
there's a one way check valve to let the air into the hose and not let it out I believe.
Old Aug 6, 2003 | 08:52 AM
sivik2nr's Avatar
how is a leakdown test done properly? Or how is it suppposed to be done?
Old Aug 6, 2003 | 09:37 AM
1.8t's Avatar
Default Re: (sivik2nr)
They way they did my buddies was they pressurized the manifold to see if it would hold pressure. He had a nicked intake valve, so it didn't. What type of equipment they use I am not sure.
Old Aug 6, 2003 | 01:12 PM
platinum00's Avatar
Default Re: (1.8t)
ahh ok that makes sense. i did not think about the check valve. damn it. how much is the real test.
platinum.
MilFhunter001
May 13, 2010 08:29 AM
crxvtecturbo
Apr 18, 2005 08:51 AM
Goldfingiz
Dec 13, 2002 10:30 PM
Seann
Nov 24, 2001 09:34 AM
quikrpm'z
Jul 6, 2001 06:29 AM
