how much psi on stock injectors
Old Aug 6, 2003 | 07:14 AM
djnikko's Avatar
Default how much psi on stock injectors
hi guys
i have a 1.6 zc euro spec engine with T3 turbo, just wondering what is the max psi i can set the turbo too without changing the injectors? i think my standard ones are 240cc.
Old Aug 6, 2003 | 04:35 PM
TravSi's Avatar
Default Re: how much psi on stock injectors (djnikko)
i can sum it up in a few words.....afc + dsm 450's + lower base ign. timing a few degrees = no low boosting worries, but if you "want " to be that guy i would say 6psi and rising rate fpr and whatever yur gonna use to fool the map sensor....
Trav
Old Aug 14, 2003 | 05:40 AM
djnikko's Avatar
I have SAFC, B&M FPR, T3 turbo (not sure what set to), bosch blow off valve, and 240cc injectors... what max psi can i run? thanks
Old Aug 14, 2003 | 05:55 AM
pissedoffsol's Avatar
25 Year Member
6 on an fmu setup is about as high as you really should go.
think about it...
stock rail pressure averages around 40 psi.
add a 12:1 fmu. 6x12 = 72.
72+ 40 = 102 psi of fuel pressure. IMO, thats way too much already.
I hate fmus and think they should die. you already have a SAFC. there's no reason why you can't spend $50 on a set of dsm injectors instead of spending $80 on a 12:1 fmu and $25-50 on missing link/check valves.
Old Aug 14, 2003 | 07:27 AM
djnikko's Avatar
Default Re: how much psi on stock injectors (pissedoffsol)
do u know where the best place is to buy 450cc injectors? also would they ship them to the UK (london)
thanks
Nick
Old Aug 14, 2003 | 08:54 AM
RudeLude's Avatar
http://www.dsmtrader.com http://www.thepartstrader.com
Old Sep 9, 2003 | 07:26 AM
djnikko's Avatar
Default Re: (RudeLude)
where can i get a check valve/missing link for $25? Also do i need one as I thought SAFC eliminates the need for missing link
laakea
Apr 3, 2006 07:13 PM
blackccoupe
Mar 28, 2004 12:25 PM
GOLDBERG
Apr 13, 2003 05:16 PM
bottlefedb18c1
Jul 1, 2002 11:50 PM
HybridCoupe
Jun 25, 2002 02:26 PM
