Check valves?? Turbo Q
Old Aug 6, 2003 | 12:22 AM
greekspeed's Avatar
Default Check valves?? Turbo Question
Hey whats up all.... my friend was telling me about these check valves that are needed (if going custom turbo) to be installed inbetween the map senor and the manifold?? so that the map sensor doesnt sense the boost....
anyone know if it is nessessary, or if anyone can shed some light on this subject.
Thanks for your time.
Modified by greekspeed at 10:56 PM 8/9/2003
Old Aug 7, 2003 | 09:13 AM
greekspeed's Avatar
Default Re: Check valves?? Turbo Q (greekspeed)
bump
Old Aug 9, 2003 | 01:55 PM
greekspeed's Avatar
bumpster
Old Aug 9, 2003 | 04:37 PM
TravSi's Avatar
to hell with those check valves...get yurself some dsm 450's and a afc and then your good to go....factory like boost and plenty of fuel, i like it better than an fmu and check valves for sure....
Trav
Old Aug 14, 2003 | 02:30 PM
J2turbo21's Avatar
Default Re: Check valves?? Turbo Question (greekspeed)
Yea he's right they are standard with most drag turbo kits,kinda ghetto rigging to me just like FMU's.
Old Aug 14, 2003 | 02:43 PM
NeEd4Spe3d's Avatar
you shouldn't get any check lites if u use a missing link but if u're using the AFC hack, the missinig link is not necessary but you will still get a check lite if you are obd2... obd1 is GOD, everything is perfect about it, lol...
Old Aug 17, 2003 | 01:39 PM
greekspeed's Avatar
Default Re: Check valves?? Turbo Question (KanMan)
so as long as i have an SAFC im good then?
Old Aug 17, 2003 | 02:32 PM
red cx's Avatar
do a search on the afc hack theres tons of stuff about it. The afc and 450 dsm injector combo is a good affordable method for factory like boost.
Old Aug 18, 2003 | 09:53 AM
1990hondaHF's Avatar
Default Re: Check valves?? Turbo Question (b16aturbopwrd)
but isn't the FMU/check valve the cheaper way to go?
REDLINEtypeR
Nov 18, 2007 05:43 PM
93accordNOS
Mar 2, 2006 07:04 AM
93hondaboy
Jan 27, 2005 02:59 PM
filetofit
Jun 4, 2002 02:56 PM
ck279
Dec 17, 2001 06:57 AM
