2.4L Bseries. How would you do it?
Old Aug 5, 2003 | 08:46 PM
yellaboi's Avatar
Default 2.4L Bseries. How would you do it?
What would be the best way to make a 2.4L B series engine. Of course boring and stroking, but What crank/rod length/ deck plate would get me a longer stroke while maintaining a good if not close to perfect rod/stroke ratio?
Old Aug 5, 2003 | 09:11 PM
Blaze45's Avatar
Brrraaaap!
Default Re: 2.4L Bseries. How would you do it? (yellaboi)
I wouldnt. I would buy a K series motor. I know the longer the stroke the harder it is to keep a good R/S ratio. Or was it B/S (bore stroke) ratio? I cant remember. Sorry I couldnt help more.
Blaze
Old Aug 5, 2003 | 09:14 PM
yellaboi's Avatar
I wish I could get a Kseries in my DC integra
Old Aug 5, 2003 | 09:24 PM
Blaze45's Avatar
Brrraaaap!
Default Re: (yellaboi)
Wouldnt that be tight? I saw an EG that had a K20 with ITBs... Crazy....
Old Aug 5, 2003 | 09:39 PM
simple4012's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellaboi &raquo;</TD></TR><TR><TD CLASS="quote">I wish I could get a Kseries in my DC integra</TD></TR></TABLE>
soon.
100mm crank and like an 86mm bore is right round it. r/s is like 1.2x or something.
Old Aug 5, 2003 | 09:47 PM
T4eg's Avatar
Default Re: (simple4012)
you would need a custom crank atleast 100mm stroke and probably 86mm bore. Then to make it last a deck plate would be needed, because the rod ratio would be VERY bad.
Old Aug 6, 2003 | 05:49 AM
fox297's Avatar
Default Re: (BlueHatch00)
Why don't you get the H23A prelude engine instead. It would be a much cheaper alternative. I'm not sure what's the R/S ratio on that though.
Old Aug 6, 2003 | 06:04 AM
Lsos's Avatar
**** man...it would probably vibrate pretty bad. Don't they start putting in balance shafts at right around 2.0 liters? After 2.4-2.5 they pretty much give up and just go to V6...
Old Aug 6, 2003 | 06:28 AM
jlicrx's Avatar
http://www.rddyno.com/prod/b_series.shtml
Old Aug 6, 2003 | 07:23 AM
owen_the_soyboy's Avatar
Default Re: 2.4L Bseries. How would you do it? (jlicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">http://www.rddyno.com/prod/b_series.shtml</TD></TR></TABLE>
092eg6
16
Dec 12, 2016 10:23 AM
The Sword
Jan 26, 2009 05:12 PM
d16dcoe45
Dec 1, 2005 12:57 PM
Justin Jones
Nov 26, 2005 04:48 PM
Nice_Dc2r
Mar 30, 2003 07:31 PM
