Possible Oil problems!!! Need some help
Old Aug 5, 2003 | 05:22 PM
98LS_VTEC's Avatar
Default Possible Oil problems!!! Need some help
Alright I won't lie I don't really no too much about cars. More than most but not as much as wish I knew. I checked my oil today and noticed that there was quit a bit of pressure built up (air pressure). I let all the air out and checked my oil, little low like always so added a little more, put dipstick back in and pulled it out right after and pressure had already built up. I did do this all with engine running. Please let me know if this is normal or if I should have it checked out before problem gets serious. Car is a 1998 Integra with LS/Vtec engine.
Old Aug 5, 2003 | 05:53 PM
quik1's Avatar
Default Re: Possible Oil problems!!! Need some help (98LS_VTEC)
You should check your oil only with the engine turned off. I have no idea what this pressure build up you are talking about is. The only reason why there might be pressure is because you checked it with your car running and your pcv valve isn't working.
captainjdog
Jan 12, 2006 08:03 AM
98LS_VTEC
Aug 5, 2003 06:46 PM
slowcivic
Jul 2, 2003 06:55 AM
r7
Aug 19, 2002 06:34 AM
