converting b16 to b18c5
Old Aug 8, 2001 | 04:38 PM
DOHCTOR's Avatar
Default converting b16 to b18c5
can i just get all the internals crank,rods,pistons,oil pump etc. and just put it into a b16 block without any mods; and will the itr head just bolt on the b16?
Old Aug 8, 2001 | 05:14 PM
owen_the_soyboy's Avatar
Default Re: converting b16 to b18c5 (DOHCTOR)
you need a stroker kit, spoon and some other companies sell them.
HTH.
Old Aug 8, 2001 | 05:16 PM
ITR head will bolt right onto a B16, but, depending on what year you have for the B16 you may have distributor wire issues I think....
check these freaks.... http://www.hybrid.honda-perf.org/
Old Aug 9, 2001 | 12:26 PM
bojangs's Avatar
New User
b18c5 crank and rods in a b16 block eh? well the pistons will sit out of the holes (remember itr block is taller then a b16 hence it utilizes longer rods) and you'll have some nice piston to head action..
good wishful thinking tho..
Old Aug 10, 2001 | 11:28 AM
bb6h22a's Avatar
Default You could..
..use a b17 rods and crank, and you would be right in the middle of 1.6 and 1.8, a 1.7 liter oem part motor, the b16 and b17 blocks are identical!
But, why would you want to stroke the b16? The b16 has the ideal rod ratio [1.75] and has nearly perfect motor geometry [less sidewall load, etc.]!
Stroker motors are for race cars, not daily dirven grocery getters, if your looking to increase displacement: bore the motor!
Then again, you wont want to grind/remove too much off the cylinder walls, either way, you would be better off just getting a b18c block and using your b16 head, which by the way will lower you compression roughly ~0.2 points, since the b16 head has a lager combustion chamber!
Also, the b16 and itr head are the SAME, less the fact that the itr head is hand polished and the valve angle is more acute, 40 or 45 degress!
Anyway, no you cant use those internals on a b16!
[Modified by bb6h22a, 8:31 PM 8/10/2001]
[Modified by bb6h22a, 8:32 PM 8/10/2001]
Old Aug 10, 2001 | 02:23 PM
rioninja's Avatar
Isnt it a fact that the 2nd gen B16a has the same block height at a GSR? i'm pretty sure the rods are just longer. Can anyone verify this? If i remember correctly, you can easily put GSR stuff in a 2nd gen...
Old Aug 11, 2001 | 06:31 AM
nomorecrx's Avatar
New User
Default Re: converting b16 to b18c5 (RioNinja)
doesn't matter what gen...the only b16 that has an identical block to a gsr is the b16b.
Old Aug 11, 2001 | 01:40 PM
rioninja's Avatar
Default Re: converting b16 to b18c5 (nomorecrx)
Yeah, i think your right. I was thinking it was the 2nd gen, but the B16b sounds more like it. Guess i didn't remember correctly
zlambe
Jul 13, 2012 06:04 AM
wagonstatus
Jul 15, 2007 01:08 PM
SiR Inspired ED7
Apr 3, 2006 07:51 PM
SiR Inspired ED7
Apr 3, 2006 07:50 PM
