Need help removing TPS (throttle position sensor)
I just got a new TB and it's TPS is bad, so I want to use my old TB TPS. This is probably a lame question, but how do I get the TPS off. It doesn't have a phillips screw like the mass air sensor and I don't want to break it fiddling around. Thanks.
easy...get yourself a dremmel cut-off wheel. put a nice deep notch into the tops of the screws..and use a flat head to remove it. good luck
polything
23
Jul 27, 2012 08:23 AM
