UK cars with 450cc injectors?
Old Aug 5, 2003 | 05:29 AM
djnikko's Avatar
Default UK cars with 450cc injectors?
anyone know of any? I need some 450cc injectors for my turbo setup on my honda. Do honda do 450cc injectors? or do I have to take them off another car? I take it the make of these injectors will be bosch or simular make. any help would be great... I know someone else in the UK with this problem too
Old Aug 5, 2003 | 06:30 AM
mamaboy's Avatar
Default Re: UK cars with 450cc injectors? (djnikko)
we in the states either go with RC Engineering or get used DSM 450cc saturated injectors + OBD1 injector clips + OEM Honda Resistor box. DSM = 1G/2G Mitsubishi Eclipse. There are other companies, but these are the popular ones
Old Aug 5, 2003 | 06:34 AM
djnikko's Avatar
Default Re: UK cars with 450cc injectors? (mamaboy)
we dont get mitsi eclipse's in the UK. Im hoping there is a ford I can take them from if not i'll order them direct from bosch. There quite pricey on ebay too, someone told me the CC of the injector is etched on the side I have looked but cannot find it, is this true?
Old Aug 5, 2003 | 08:02 AM
rioninja's Avatar
Check out DSMtrader.com, you can usually find a set of 450s for $50. Probably cost you another $15 to ship them to london.
Old Aug 5, 2003 | 08:26 AM
mamaboy's Avatar
make sure to clean and balance them.....if you buy used injectors......and yes you can see the injector cc's on DSM injectors....it's usually stamped on rather than etched.....RC injectors on the other hand has etchings i believe......blue top is the older ones....black tops are the new ones.....here's an idea try getting in contact with roadraceengineering.com...I got my DSM injectors fresh from a 2G eclipse they were upgrading.....if you need the OBD1 clips and resistor box PM Sonny on this board.....
Old Aug 5, 2003 | 09:14 AM
NOSED_CRX_VTEC's Avatar
Had The same problem when i was doing my turbo setup.
Easy thing to do is get them off of ebay, If you search well you will find a cheep set.
I payed $65 shipped to the UK.
And Cleaning them cost about £14 per injector at P.T.S. in Luton.
I don't know if you know this but UK spec honda already have the resister box.
ceemarun
Aug 7, 2015 05:21 PM
LUiS010606
May 3, 2010 09:58 PM
aryiman98civic
Feb 23, 2007 07:03 AM
gents97civ
Oct 26, 2004 07:26 PM
Adriano
Oct 15, 2002 06:53 PM
