Stupid question, needs intelligent answer :P
Old Aug 4, 2003 | 10:06 PM
Nathan007's Avatar
Default Stupid question, needs intelligent answer :P
I know this sounds really stupid, but im french so i dont know all those english terms.. Whats the difference between Closed Deck and Open deck?
Heard about it while getting info on H22 engine..
any help would be gladly appreciated!!
Thank you
Old Aug 6, 2003 | 09:49 AM
Nathan007's Avatar
anyone!?
Old Aug 6, 2003 | 10:01 AM
Katman's Avatar
Default Re: Stupid question, needs intelligent answer :P (Nathan007)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nathan007 &raquo;</TD></TR><TR><TD CLASS="quote">I know this sounds really stupid, but im french so i dont know all those english terms.. Whats the difference between Closed Deck and Open deck?
Thank you </TD></TR></TABLE>
Not a dumb question if you're yearning for knowledge.
Most-all Honda engines are 'open deck'.
Here's a picture of B-series 'open deck' block:
Notice the open trench area surrounding the cylinder walls? That's what makes a Honda motor 'open deck'. Coolant resides in that surrounding trench.
closed deck is seen here (no surrounding trench):
Old Aug 6, 2003 | 10:14 AM
Need4Boost's Avatar
Default Re: Stupid question, needs intelligent answer :P (Katman)
Is there any advantages or disadvantages to open and closed decks???
Old Aug 6, 2003 | 10:22 AM
Katman's Avatar
Default Re: Stupid question, needs intelligent answer :P (Need4Boost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Need4Boost &raquo;</TD></TR><TR><TD CLASS="quote">Is there any advantages or disadvantages to open and closed decks???</TD></TR></TABLE>
Closed decks are more stable because the top of the cylinders have support, instead of being open. But, you can make a Honda block a somewhat closed deck by purchasing one of these cylinder plates:
This only needed if your making big power with your engine though (turbo).
Old Aug 6, 2003 | 10:33 AM
Need4Boost's Avatar
Is that the same thing as a "block guard"&lt;--- stupid question i know, but educate me.
Old Aug 6, 2003 | 10:38 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Need4Boost &raquo;</TD></TR><TR><TD CLASS="quote">Is that the same thing as a "block guard"&lt;--- stupid question i know, but educate me. </TD></TR></TABLE>
yesh it is.
Old Aug 6, 2003 | 10:44 AM
Need4Boost's Avatar
Cool, I thought so...thanks man
Old Aug 6, 2003 | 03:38 PM
Nathan007's Avatar
Hey thank you very much!! This couldnt have been clearer!! I'll go to sleep less stupid tonight hehehe
Old Aug 6, 2003 | 06:15 PM
hondapwr's Avatar
One more thing about the design. Honda engines were designed with an open deck for a big increase in cooling efficiency. This allows the car to be lighter by using less block material and using a smaller radiator.
sshh
Aug 16, 2013 05:42 AM
skUnK2jdm
May 19, 2008 10:11 PM
j spec
Oct 6, 2005 11:46 AM
one4darkstar
Mar 17, 2005 10:58 AM
