Clutch.
Old Aug 4, 2003 | 06:09 PM
Slow89HB's Avatar
Default Clutch.
Hey guys, I got a question for everyone, and yes, I searched.
So anyways i got out for a spin one day, come home, everythings fine, park the car, leave it. 2 days later I go out to my car and get in, start it up, put the clutch in, try to put it in reverse, and heard that horrible gear grinding sound, so i let go of the clutch, pushed it in again, and tried it again, the same thing happening, so I try going into first, while the car is on, no dice, no dice for the 3 other gears either, it goes into the gears fine when the engine is off, so i think its the clutch. I already have the clutch to install, but am wondering if theres a quick fix, or do i have to pay the 260~ to get it installed. Thanks. Il put up a pic if theres any interest.
Old Aug 4, 2003 | 08:50 PM
VashTheStampede's Avatar
No tears. Only dreams, now.
Did it slip before? When was the last time you had it fixed? What tranny/engine?
Old Aug 4, 2003 | 10:20 PM
Vinceg99's Avatar
Default Re: (VashTheStampede)
You could also try the adjuster under the hood on the tranny maybe its just out of adjustment??
Old Aug 4, 2003 | 11:01 PM
Slow89HB's Avatar
D15b, not sure about tranny, 4 speed manny. Yea it did slip a little bit, but not taht much, it was fine, let it sit 2 days, bam didnt work. And what do you mean by the adjuster?
Old Aug 5, 2003 | 04:52 AM
bagged89hatch's Avatar
Default Re: (Slow89HB)
if you put it in gear then start it what happenes does it move does it stay still
Old Aug 5, 2003 | 07:25 AM
Vinceg99's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slow89HB &raquo;</TD></TR><TR><TD CLASS="quote">And what do you mean by the adjuster?</TD></TR></TABLE>
There is an adjuster right on the tranny itself that adjusts the cable so that it takes the slack out if your clutch is wearing down.
Old Aug 5, 2003 | 07:40 AM
Clementine's Avatar
yeah sounds like you dont have enough engagment their and should prolly just be adjusted. i have never heard of clutch wear before just from a car not even turned on haha.
Old Aug 6, 2003 | 08:07 PM
Slow89HB's Avatar
Well il go out and see what i can do, but it pulls pretty tight when u press down the clutch.
Old Aug 6, 2003 | 08:41 PM
Slow89HB's Avatar
Does anyone have a schematic of the tranny/clutch? Im trying to figure out how to tighten the cable.
Old Aug 6, 2003 | 11:06 PM
Slow89HB's Avatar
bumpbump bump bump it up
Old Aug 8, 2003 | 08:35 AM
Slow89HB's Avatar
Someone please!!!
Old Aug 9, 2003 | 01:52 PM
seditiouscivic's Avatar
Same thing happend on my car, put the clutch in about half way then see if it will shift. It should just be clutch cable also make sure what fluid u put into your tranny. My 89 si used 10w30 or 10w40 motor oil , with the ratings sg, sf
Old Aug 10, 2003 | 01:17 PM
Slow89HB's Avatar
Where is the cap for the tranny fluid?
mfisher1987
Transmission & Drivetrain
Feb 8, 2015 05:58 PM
slowdaintegra
Dec 21, 2005 01:31 PM
tony88crx
Jun 21, 2005 06:37 PM
Odiedogcx
Honda Motorcycles
Jan 1, 2005 08:59 PM
dan89crxsi
Oct 12, 2004 01:32 PM
