Pos engine still not starting
Old Aug 4, 2003 | 03:20 PM
jumpmann23's Avatar
From: Your really lame if you dock my points, WA, 98033
Default Pos engine still not starting
Modified by Jumpmann23 at 12:20 PM 2/20/2004
Old Aug 4, 2003 | 03:25 PM
OnePointFive's Avatar
overrated.
Default Re: Pos engine still not starting (RuthlessEj6)
try posting this in the hybrid forum, i always get a response there.
Old Aug 4, 2003 | 03:46 PM
EK MONEY's Avatar
Default Re: Pos engine still not starting (OnePointFive)
swap king! i live in your city PM me for help.
Old Aug 4, 2003 | 04:23 PM
jumpmann23's Avatar
PM sent
Old Aug 4, 2003 | 04:29 PM
poison's Avatar
Ok keep me posted on this. No spark, no fuel pump priming = bad ECU, bad jumper harness, OR the main relay screwed.
First of all, with the key in the ON position.......does the CEL go on for 2 seconds then go off, or does it just stay on the whole time?
Check the ECU fuse, ECU back up fuse, (both under the hood) and the ACG fuse (next to the SRS fuse under the dash).
Old Aug 4, 2003 | 04:41 PM
Shawn C's Avatar
In The Garage
Default Re: Pos engine still not starting (poison)
also, you need to run B-series injectors and fuel pump. sounds like possibly a ground problem, and maybe a bad main relay. do you have powa to the main relay?
edit- also, you don't need to check injectors for voltage, you need to check for pulse. injectors usually get ~10.x volts. do you have a spark?
jumpmann23's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison &raquo;</TD></TR><TR><TD CLASS="quote">Ok keep me posted on this. No spark, no fuel pump priming = bad ECU, bad jumper harness, OR the main relay screwed.
Check the ECU fuse, ECU back up fuse, (both under the hood) and the ACG fuse (next to the SRS fuse under the dash).</TD></TR></TABLE>
we checked mainrelay and that was fine. even replaced it with a buddy of mines who has a 96 cx.
when the car is turned to the on postion the engine light stays on the whole time.
the car has spark and is now getting fuel cause we wired the fuel pump to the ignition before it wasnt getting any power at all.
Old Aug 4, 2003 | 04:42 PM
jumpmann23's Avatar
Default Re: Pos engine still not starting (22lbGS-R)
i also ended up changing the fuel pump to a ITR/GSR fuel pump
Old Aug 4, 2003 | 04:45 PM
poison's Avatar
Ok, the CEL should come on and go off after 2 seconds. Check the ACG fuse next to the SRS fuse under the dash.
Old Aug 4, 2003 | 04:47 PM
Shawn C's Avatar
In The Garage
ok, well you need some injectors out of something like a B16A3, 94-95 B18B1, 94-95 B18C1, etc. also, make SURE the ecu is grounded. the ground is under the hood, at the thermostat housing (back of the block, where lower radiator hose connects)
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 22lbGS-R &raquo;</TD></TR><TR><TD CLASS="quote">ok, well you need some injectors out of something like a B16A3, 94-95 B18B1, 94-95 B18C1, etc. also, make SURE the ecu is grounded. the ground is under the hood, at the thermostat housing (back of the block, where lower radiator hose connects)</TD></TR></TABLE>
good point, AND the tranny ground secure
Old Aug 4, 2003 | 04:50 PM
jumpmann23's Avatar
so are you saying the d series injectors will not work??? ive been told here on honda tech that b series and d series injectors are the same and flow at 240cc.
Old Aug 4, 2003 | 04:53 PM
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RuthlessEj6 &raquo;</TD></TR><TR><TD CLASS="quote">so are you saying the d series injectors will not work??? ive been told here on honda tech that b series and d series injectors are the same and flow at 240cc. </TD></TR></TABLE>
I have heard that, but I've always converted the harness to use the B series injectors.
Old Aug 4, 2003 | 04:58 PM
Shawn C's Avatar
In The Garage
well, my friend brian (Plan B on here, knows his ****) had d-series injectors on his built gs-r, and it ran like ****. (the car has 12.5:1 cr) he put in 99-00 Si injectors, and it runs awesome.
edit- note- it will run with d-series, though. look for a ground/relay/sensor/ecu problem
Old Aug 4, 2003 | 05:02 PM
poison's Avatar
Default Re: (22lbGS-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 22lbGS-R &raquo;</TD></TR><TR><TD CLASS="quote">well, my friend brian (Plan B on here, knows his ****) had d-series injectors on his built gs-r, and it ran like ****. (the car has 12.5:1 cr) he put in 99-00 Si injectors, and it runs awesome.
edit- note- it will run with d-series, though. look for a ground/relay/sensor/ecu problem</TD></TR></TABLE>
lol ya. I just always used the B series, but if it'll work good
good pointers bro
Old Aug 4, 2003 | 05:23 PM
jumpmann23's Avatar
Default Re: (poison)
i plan on using b series injectors. i just want to get the motor started first.
quick question i checked for the ACG fuse and couldnt locate it. what does ACG stand for?
Old Aug 4, 2003 | 05:26 PM
poison's Avatar
Default Re: (RuthlessEj6)
It's next to the SRS fuse. This completes the circuit with the main relay/ecu.
I remember seeing what ACG stands for according to Helms a while back, but I can't friggin remember, now you're killing me!
it'll hit me eventually lol
Old Aug 4, 2003 | 05:35 PM
jumpmann23's Avatar
dont worry it will probably come to you when your not thinking about it.
i just thought of somethign that it could possibly be. i had to rewire my distrbutor
beacause it didnt plug up to my harness. the distributor was off a obd2b engine,
so we cut the plug off and used the plug of my d16 and color matched the wires
and used but connectors. on the hybrid forum on ht i posted this topic and
someone mentioned if the the distributors wires arent right it wont send spark or
fuel to the combustion chamber.
Old Aug 4, 2003 | 05:38 PM
poison's Avatar
That is correct. main relay has to do with it, ALSO being the ignitor unit. the ignitor unit has to do with it as well.
jumpmann23's Avatar
so its a big chain of headaches. ****
Old Aug 4, 2003 | 05:41 PM
Shawn C's Avatar
In The Garage
Old Aug 4, 2003 | 05:44 PM
Shawn C's Avatar
In The Garage
ha ha ha, damnit
okay, well like the ****** pst was supposed to say, are you running a vtec dist? or a non-vtec dist?
Old Aug 4, 2003 | 05:48 PM
jumpmann23's Avatar
vtec distributor.... hah i was gonna say something to why you posted the same thing twice but i figured to keep my mouth shut
eg8_civic_253
Apr 30, 2025 10:21 PM
mouab18c1
13
Jul 23, 2011 05:23 PM
f20cmx5
11
Mar 25, 2011 04:57 PM
si90rex
Jun 24, 2007 05:53 PM
digitalcongo
Nov 14, 2003 04:27 AM
