d16z6 swap. no spark!!???
the connector coming of the distributor that has a black wire with yellow stripe and a seperate blue wire isnt connected to anything. where does it go?
if your car is wired for obd0, the obd1 distributor will not work. you need to get a obd0 to obd1 jumper, and convert your car to obd1 in order to run that distributor. you'll need the jumper harness, obd1 distributor, obd1 O2 sensor, and a obd1 ecu!
ryanangelo212
Mar 18, 2013 12:23 AM
VegasInvasion
Jul 1, 2010 10:49 AM
