Need help quick...Motor Mount is broken...
Old Aug 8, 2001 | 07:37 AM
AWDSOME's Avatar
Default Need help quick...Motor Mount is broken...
I was taking off one of my engine mounts in order to put my AC belt back in and the bolt started to spin the actual mount as i tried to take it off. Being a novice wrencher I kept trying to remove the bolt. Anyway long and short of it is that the nut on the end did not come off and instead the bolt came out that is normally attached to the engine. Needless to say this meant the the motor mount itslef had been broken in order to allow the bolt to spin freely.
****...no Acura dealers have any in stock. How bad would it be to drive without the mount for a day or to until one comes in? Also, would this be cover under warranty? I had E/S motor mount inserts, but i can remove the other side insert and then it would not matter. Any information and help is much appreciated
scubacamper
Jul 4, 2015 10:29 PM
lilo_goki
Jan 5, 2011 08:36 PM
TEGRA98GSR
Apr 21, 2010 09:47 PM
00WhiteEKy
Jun 22, 2003 08:54 AM
00WhiteEKy
May 30, 2003 10:09 AM
