overheating at high speeds
Old Aug 4, 2003 | 12:06 AM
windg@t's Avatar
Default overheating at high speeds
Hi
Before the engine swap , the radiator had a recore, and was working fine, now aftar the engine swap and moddifications the engine tneds to run hot, up to 100 Degrees celsius when doing high speed runs, as soon as you start to slow down, then after a while the temp goes back to normal. The termostat is new and works properly, as well as the fan. Could it be the recore, or is the radiator to small. The headers also runs close to the radiator, would termo wrap perhaps help.
Any advice please.
Thank you
Old Aug 4, 2003 | 04:12 AM
1bad-eg's Avatar
Default Re: overheating at high speeds (windg@t)
What kind of car is it?
Old Aug 4, 2003 | 04:37 AM
Russ713's Avatar
dAng!
radiator might be too small
could have a blown headgasket
could have air in the coolant system
could be a bad thermostat
check coolant levels first, then check if there's air in the system.
Old Aug 4, 2003 | 05:02 AM
windg@t's Avatar
Default Re: overheating at high speeds (Russ713)
Thanks for the reply.
Its a 1986 honda 150, with a 150 engine, head was done (1mm) and the cam was reprofile and the carb was replaced by a weber 36 dcd 7. The termostate is new and working, no blown head gasket, coolant levels are normal and system has been blead. Could it have something to do with the timing or not. Still needs to get a variable cam pulley to adjust the timing.
Old Aug 4, 2003 | 08:46 AM
GZERO's Avatar
what about raditor cap? people tend to forget this.
Old Aug 4, 2003 | 08:48 AM
Russ713's Avatar
dAng!
Default Re: overheating at high speeds (GZERO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GZERO &raquo;</TD></TR><TR><TD CLASS="quote">what about raditor cap? people tend to forget this.</TD></TR></TABLE>
yeah, that too. I forgot that i've had a radiator cap cause problems for me also on an older prelude.
pcteck
Oct 5, 2010 06:02 AM
soclean1k_JDM
25
Aug 6, 2008 07:23 AM
Shintakun
Honda Civic (2001 - 2005)
Jan 26, 2008 07:44 PM
pentaq
Feb 14, 2006 05:18 AM
intekragsr
Nov 30, 2002 08:15 AM
