Turbo manifolds that allow the A/C
Tinkers sidewinder manifold, http://www.lovefab.com
Hy-techs manifold. not sure on the website, search it.
Revhard lets you do it with one of theres, if you run a 2.5inch dp.
Quite a few mani's might let you if you run a smaller dp.
In order to get a 65mm dp to fit I had to be really creative with my Kiwi setup. That nasty bend was causing spool up problems so I ditched the AC for more space and a smooth radius 70mm dp.
Yes, homework is a MUST to avoid an expensive error. With the SideWinder, for example, you have to re-route the upper radiator hose. It can be done easily, but if someone wasnt expecting it(which I tell everyone TO expect it), it can create mucho anger
But the upside is a full 3" DP, and a gargantuan turbo for that Supra-stompin power while the AC is blowin!
808speedSyndicate
Oct 11, 2009 11:39 AM
kun3racer
Mar 7, 2004 02:01 PM
