gsr si?
depends on what year ecu is it, if its from a 99-00 it should plug right up, if its from 96-98 then you will need an obd2b>obd2a jumper, and if its obd1 you will need an obd2b>obd1 jumper
FliiBoii
26
Nov 23, 2011 12:43 PM
Are the 99-00 SI ECU pluggs same as the 99-01 GSR and what wires have to be changed to make it work?
underrated99si
Apr 1, 2003 01:29 PM
