Mayjor problem!! Need fast help!!
Old Aug 3, 2003 | 07:28 PM
b20ek's Avatar
Default Major problem!! Need fast help!!
I can't get my car to start. I keep blowing the (15) fuse under the hood (FI E/M) and my fuel pump won't prime. It keeps blowing so I must have a short somewhere. I have a cel but it won't allow me to check it. When I jump the service connector the cel won't blink so I don't know what the problem is. I tried a different ecu and I still have the same problem. I don't know what to do. I need help bad!
Modified by b20ek at 8:49 PM 8/3/2003
Old Aug 3, 2003 | 07:40 PM
sackdz's Avatar
Default Re: Mayjor problem!! Need fast help!! (b20ek)
You have a short. Did you do any wiring or any modifications to the car whatsoever recently? I would look there first.
Old Aug 3, 2003 | 07:50 PM
b20ek's Avatar
Default Re: Mayjor problem!! Need fast help!! (sackdz)
I have an obd2 to obd1 conversion harness, I've extended my o2 sensor, extended my injectors. What Could cause this fuse to continue to blow?
Old Aug 3, 2003 | 08:34 PM
sackdz's Avatar
Most likely you wired somthing incorrectly. The secondary and primary o2 are both on that circuit I would look there first. Disconnect one sensor at a time then replace the fuse and see if the problem is gone. If they are good then do the same with injectors.
Old Aug 4, 2003 | 04:14 AM
1bad-eg's Avatar
wjones123
14
Feb 3, 2011 07:06 PM
SC61HB
Oct 11, 2008 07:55 AM
em1si
10
Sep 6, 2007 06:08 AM
wolf3007
Jun 4, 2006 12:55 AM
beaterdriver
Mar 4, 2005 12:36 PM
