help please why is my car hisitating
Old Aug 3, 2003 | 06:49 PM
superturboprelude's Avatar
Default help please why is my car hisitating
hi my car has been runnning very rich and it has been hesitatin at 3-4ooo rpms even at idle it hesitates i have changed my plugs, wires and cap and rotors and and its still does the same thang but the i still have the orignal distributor on the h22a jdm motor but the distributor has 230,000 miles its a h23a distributor the check engine light only comes on some times though not every time i drive so i dont know what to do please help
Old Aug 3, 2003 | 07:09 PM
Cottonwoodz's Avatar
Default Re: help please why is my car hisitating (superjunprelude)
Pull the code... The ECU stores every cel that goes off, untill the ECU is reset.. That should point you in the right direction.
Old Aug 3, 2003 | 07:24 PM
Default Re: help please why is my car hisitating (Cottonwoodz)
yeah but the check engine rarely ever comes on though and it still hesitates and runs very run no power at high rpms
Old Aug 3, 2003 | 07:43 PM
The CEL should never come on..So you got a problem somewhere.
Old Aug 3, 2003 | 08:36 PM
yeah the cel comes on because the egr is blocked valve off but that is not why the car hesitate so please let me know thanks
Old Aug 3, 2003 | 09:40 PM
Jason kiDD's Avatar
I would take a look at the ICM, or ignitor. Make sure all the connectors are tight on it.. Is the car missing when you rev or drive?
Old Aug 4, 2003 | 04:43 AM
lildrgn2.0's Avatar
New User
This is the same problem we had on the gumball.
Does it take off kinda slow and slowly start to build up?
Does Vtec engage at the correct time, or does it seem to be a little late like at 5200 or higher?
If it is, your auto tensioner is failing. Todd and I figured that is the only reason that the car was retarding itself while we were driving to and from California.
EDIT: and yes, we were running really rich.
Mr. Bojangles
Apr 26, 2013 07:47 PM
new_climber
15
Mar 29, 2013 09:29 PM
puffsef
Aug 25, 2005 07:18 AM
CornFlake340
Jul 24, 2005 04:09 PM
si95
Sep 5, 2002 11:42 AM
