Oil Pressure question
I was wondering what the oil pressure should be at idle for a GSR motor. I'm running a tee off of the back of the block with a turbo oil feed line and the electronic oil pressure gauge. At idle I'm getting about 13psi. Does this sound fine or should it be higher?
When I first start the car and let it warm up, I get about 25 psi as well. After I come home from a long ride and I let the turbo timer count down, this is when I usually see the 13psi at idle. I was concerned about that and I didn't really think about the temp. of the oil and how it affected the oil pressure. Thanks for clearing that up and I appreciate your help. Thanks.
Excusetobooost
Jun 9, 2020 01:19 PM
TeamSeanFTW
Mar 15, 2011 06:41 PM
