how to get oil pressure sensor off b18c1??
i searched and all i foudn were posts that showed pix of how to get it off d series motors. i have my gsr motor sitting in my garage and was trying to run my oil feed line for turbo, well when i get the rubber boot off i try to get a socket over the sensor and it wont fit.... it appears that the sensor is too close to the oil filter and there is a metal hose that sits so close to the oil pressure sensor that i can not get a socket to fit over the sensor. i tried a closed and open ended wrench and no go.. how am i supposed to get the sensor off???
so u used a 15/16 hex socket on a b series vtec motor to get the oil pressure sender off and never had a clearance problem with the socket? thats so weird because my socket (even tried a thin walled socket) wont even fit over it because theres a metal hose coming off the oil filter assembly that is way too clos to teh oil pressure sender unit. i will keep trying
