enlighten me on oil leak and white smoke
Old Aug 3, 2003 | 05:10 PM
Mindtrap's Avatar
Default enlighten me on oil leak and white smoke
my car has about 190,000 miles on it and it's leaking oil pretty bad. I guesstimate about 1 qt per 1500 miles. The tranny oil disappears rather abruptly as well. On a few occasions after a long drive, the cat converter begins to smoke. I probably already know the reason but need confirmation... what's wrong with my car? thanks
Old Aug 3, 2003 | 11:29 PM
Jay J's Avatar
Prince of Zamunda
Default Re: enlighten me on oil leak and white smoke (Mindtrap)
The cat is gone south also the oil leak should be from the seals. Check the crankshaft area.
Old Aug 7, 2003 | 01:09 PM
Mindtrap's Avatar
Default Re: enlighten me on oil leak and white smoke (neuspeed)
okay thanks, the cat is probably collecting the oil and clogging..
Old Aug 7, 2003 | 01:30 PM
nonsense's Avatar
is this 'internal' or 'external' leaking? If it's leaking internally (i.e. burning lots of oil, then maybe your cat is clogged)
If you're just leaking oil, maybe it's leaining down onto the cat and smoking off. Get under the car and wipe off any oil buildup. Then run the car for a while and get back under there to see where it's leaking from (i.e. seals, VC gasket, oil pan).
nengx07
44
Feb 6, 2009 09:29 PM
DennMann89
Honda Civic (2001 - 2005)
Jul 30, 2008 09:39 AM
GoldCoin
Apr 14, 2008 09:16 PM
oemDC2
Mar 22, 2004 10:03 PM
lenn
Mar 8, 2004 04:04 PM
