No clutch alignment tool help!
Old Aug 3, 2003 | 01:26 PM
egizzle8
Guest
Posts: n/a
Default No clutch alignment tool help!
I swapped in a my lx flywheel onto my y7 cause I heard to use the flywheel and clutch that goes with the tranny plus the y7's flywheel had some pretty bad heat spots. I don't have a clutch alignment tool and is there any other way to align it without one?
Old Aug 3, 2003 | 01:27 PM
mmuller's Avatar
Mad Scientist
Default Re: No clutch alignment tool help! (88boostedzcrx)
yes by going and buying one
Old Aug 4, 2003 | 11:35 PM
Esoterikos's Avatar
Default Re: No clutch alignment tool help! (mmuller)
call around...you might find a local tranny shop that will let you borrow one. i did that on saturday!
Old Aug 4, 2003 | 11:46 PM
deepgreengsr's Avatar
Default Re: No clutch alignment tool help! (S8P-tuner)
there is a universal allignment kit out there. its basically a bunch of spacers and collets etc. or go to honda and get one.
Old Aug 5, 2003 | 01:41 AM
ill phil's Avatar
Default Re: No clutch alignment tool help! (deepgreengsr)
I would definitely just ask a Honda mechanic or someone who deals with them, they may have an extra one laying around from a clutch kit. Visually, maybe its just be me, but you can see when its off or when centered. I know when I've been just slightly off, the tranny won't mesh with the block. So just get a tool from a shop or buy one- they are cheap
Old Aug 5, 2003 | 03:07 AM
97hb's Avatar
I have used a broom stick and eyed it before, but I have done a couple clutch swaps.
Old Aug 5, 2003 | 03:28 AM
d15b7racer's Avatar
Default Re: No clutch alignment tool help! (97hb)
i just stuck my finger inside and sorta lined it up and jammed the tranny in. worked fine....just line it up by eye
Old Aug 5, 2003 | 04:56 AM
b19coupe's Avatar
You can align it by eye, but you better get it close, or you will struggle to get the tranny on.
Old Aug 5, 2003 | 07:07 AM
Swift's Avatar
go to the parts store it is worth a couple of bucks to not go through the pain of trying to force fit it.
Old Aug 5, 2003 | 02:26 PM
PupaScoopa's Avatar
Default Re: No clutch alignment tool help! (Swift)
...Struggling with a 80lb chunk of metal is no fun either.
Old Aug 5, 2003 | 02:38 PM
Frankie324's Avatar
Default Re: No clutch alignment tool help! (PupaScoopa)
be sure to take your clutch.
in my brother's zc swap the clutch was for a 89 crx (he wqs using the crx tranny) and we got the wrong clutch tool wrong twice?? i was like wtf?? we took the cluch and the correct part was for some GM clutch. go figure?
Old Aug 8, 2003 | 07:40 AM
T4eg's Avatar
Default Re: No clutch alignment tool help! (Frankie324)
you could just eye it. I've dont that alot of times when I didnt have the alignment tool.
Old Aug 8, 2003 | 10:21 AM
R6Boy69's Avatar
Default Re: No clutch alignment tool help! (BlueHatch00)
just eye it... its easy enough. but if you plan on taking a couple clutches apart may as get you own. they are cheap anyway.
EDWINV00SI
24
Oct 13, 2011 06:08 PM
hammergunner
Sep 13, 2008 03:58 PM
TRE_
16
Mar 9, 2003 09:25 AM
