brand new clutch but tranny is slipping?!
Old 10-11-2011, 02:30 PM
EDWINV00SI's Avatar
Icon3 brand new clutch but tranny is slipping?!
SUP HT I JUST SWAPPED A DIFFERENT B16 TRANNY ONTO MY EM1 WITH NEW EXEDY OE CLUTCH KIT BUT DIDNT REPLACE THE FLYWHEEL MY MECHANIC SAID IT LOOKED PRETTY WORN OUT BUT I KEPT IT. NOW MY CAR FEELS LIKE THE CLUTCH IS SLIPPING! I PRESS THE GAS & THE CAR DOESNT REACT TO IT AND ALL OF A SUDDEN IT CATCHES GEAR? AM I LOOKING AT A BAD FLYWHEEL OR SENSOR? OR MAYBE WRONG CLUTCH INSTALLATION? PLEASE LMK THANKS
Old 10-11-2011, 02:33 PM
EDWINV00SI's Avatar
Default Re: brand new clutch but tranny is slipping?!
forgot to mention that previous owner adjusted the clutch pedal for faster shifting. can that cause it to slip?
Old 10-11-2011, 02:35 PM
92lxsleeper's Avatar
should have replaced that flywheel
Old 10-11-2011, 02:37 PM
EDWINV00SI's Avatar
i know :/ but does the flywheel cause the clutch to slip?
Old 10-11-2011, 03:04 PM
well considering that the clutch is pressed against the flywheel.. then yah. it can only slip between the clutch and flywheel, or the clutch and pressure plate. and clutch kits come with new pressure plates, so i'm putting my money on the flywheel.
Old 10-11-2011, 03:49 PM
The Grumpiest
grumblemarc's Avatar
Should have done it all at the same time.
Old 10-11-2011, 04:47 PM
D16SiHatch's Avatar
yep. its like $40 to have it resurfaced. should have done it while it was out
Old 10-11-2011, 04:55 PM
EDWINV00SI's Avatar
i just bought an exedy fidanza lighten flywheel. hopefully this is where the problem is at
i know :/
Old 10-12-2011, 09:28 PM
EDWINV00SI's Avatar
this morning my tranny was making a grinding noise what may that be?
Old 10-12-2011, 09:37 PM
Former User's Avatar
Check whether one axle is not fully inserted and locked into the differential.
Old 10-13-2011, 08:21 AM
EDWINV00SI's Avatar
is that whats causing the grinding noise or the slipping?
Old 10-13-2011, 08:23 AM
It's a real possibility.
Old 10-13-2011, 12:07 PM
OnlyJapan's Avatar
If it didnt make the noise before you had it made then it might be bad instilation of the clutch... You better stop driving before you **** it up even more..
Old 10-13-2011, 02:23 PM
EDWINV00SI's Avatar
well my fidanza lighten flywheel just came in & my local honda/acura shop is charging me $450 for installation & rear main seal is that too much?
yup no more driving it till i get it fixed
Old 10-13-2011, 02:31 PM
is it too much for you?
personally id just grab a haynes manual and tear it apart. there is no excuse to not too. how do you think all of us learned to do it? you can do it in your driveway with basic hand tools and a couple jackstands
Old 10-13-2011, 02:57 PM
EDWINV00SI's Avatar
somewhat but i know the job is gnna be done right. doesnt the clutch have to be torque down a specific amount?
Old 10-13-2011, 02:59 PM
The Grumpiest
Get a torque wrench and a manual.
Old 10-13-2011, 03:06 PM
EDWINV00SI's Avatar
well my friends mechanic is gnna do the job for $150 i will be there watching & helping out. what should i be paying attention too specifically?
the only way you know its done right, is if you do it right yourself.
Old 10-13-2011, 03:07 PM
EDWINV00SI's Avatar
^^^true, but i trusted my dad & uncle & they failed -__-
Old 10-13-2011, 04:07 PM
no. you failed because you told them to reuse the stock flywheel without atleast resurfacing it. they told you it was worn, and you opted to keep it. shame on your part.
Old 10-13-2011, 04:11 PM
EDWINV00SI's Avatar
i went & did it cause they wanted to finish quickly :/
Old 10-13-2011, 05:08 PM
and now you see what rushing a job accomplishes.
Old 10-13-2011, 06:02 PM
fallrivercolin's Avatar
How is it that we never have time to do things right, but always find time to do them twice?
Old 10-13-2011, 06:08 PM
The Grumpiest
That's sig worthy right there.
nitewolf
11-08-2007 12:03 PM
aZnjCC
03-06-2006 07:09 AM
allmotor99lude
07-07-2005 08:01 PM
Quick Reply: brand new clutch but tranny is slipping?!
