CTR Pistons, JDM Type R Pistons, High Compression
Old Aug 3, 2003 | 01:00 PM
Heisdan's Avatar
Default CTR Pistons, JDM Type R Pistons, High Compression
I'm debating on whether to go n/a or jrsc .. w/ maybe 6 PSI, since my compression is about 180/180/180/180 on a 80K motor.. I'm goin to have to "rebuild it" if I sc or go high compression.. so .. I'm going high compression..
Agree?
Next.. if I do go high compression
.. CTR pistons are too high compression for 91 pump gas correct?
So.. JDM type R pistons are next.. OR????
should I just get aftermarket pistons? .. since I'm rebuilding.. or can I get away w/ just replacing pistons/rings and cheaper stuff than rebuilding..
Thanks
Old Aug 3, 2003 | 01:03 PM
ciRcuitJerk's Avatar
jus f0 dekarayshunZ
Default Re: CTR Pistons, JDM Type R Pistons, High Compression (Heisdan)
jesus christ your all over the place...you want to do hc and a supercharger???
Old Aug 3, 2003 | 01:06 PM
Heisdan's Avatar
lol.. no .. I'm trying to decide what kinda high compression to go..
YES I'M ALL OVER THE PLACE CAUSE I WANT 2 CARS.. FI AND N/A BUT WE CAN'T ALL HAVE THAT LOL..
So reliability and drivability.. would be high compression.. sound good?
Old Aug 3, 2003 | 01:10 PM
jus f0 dekarayshunZ
Default Re: (Heisdan)
imo i think a supercharger at 6psi and tuning is about the same as a itr compressioned(new word) car with tuning...you can make a lot of cars reliable if you tune it right...i would personally go with itr pistons cause they are ok to run on pump gas ...whereas ctr pistons are a bit high for 91 ...you can run it on pump gas if tuned properly..but im sure it would be safer with higher octane
Old Aug 3, 2003 | 01:12 PM
P1mpSlap's Avatar
CTR pistons will run on 91 if they are tuned. That or run a thicker headgasket.
Old Aug 3, 2003 | 03:43 PM
Heisdan's Avatar
I've Looked at http://www.c-speedracing.com/h...c.php and I see that it only works sometimes.. (weird)
What would be my compression w/ USDM ITR Pistons..
w/ JDM ITR pistons..
Old Aug 3, 2003 | 04:21 PM
NA gs-R 05 C
Guest
Posts: n/a
i say u stick wit all motor and go high compression.
Old Aug 4, 2003 | 06:21 AM
Heisdan's Avatar
w/ JDM ITR pistons?
Where can I find specs like this?
Old Aug 4, 2003 | 06:58 AM
cw98typer's Avatar
u don't have 93 octane. I run m ctr's daily on 93 pump gas in Fl. see sig...
Old Aug 4, 2003 | 07:07 AM
xJ.SLOTHx's Avatar
id say to just get the ctr/pct slugs, shotpeen your existing rods and get some arp rod bolts and call it a day
Vpenh
Jul 30, 2006 12:26 PM
itr1244
May 12, 2005 10:30 AM
94gsr18kid
10
Jan 25, 2005 05:35 PM
94gsr18kid
Jan 25, 2005 09:02 AM
jap-spec
Jan 16, 2003 09:35 PM
