Bottle neck in stock ITR exhaust
Old Aug 7, 2001 | 10:37 PM
Toda Party's Avatar
Default Bottle neck in stock ITR exhaust
I forgot who but someone said that there's a cheap way to fix this...anyone have some more info?
also, other than that bottleneck, the stock exhaust is fine right? i'm notgonna be running any thing really heavy duty.....
Old Aug 7, 2001 | 10:38 PM
B18C-EJ1
Guest
Posts: n/a
Default Re: Bottle neck in stock ITR exhaust (NBP ITR 01-622)
cut it off, and have a new part rewelded back on that's larger.
Old Aug 7, 2001 | 10:41 PM
Chris's Avatar
Default Re: Bottle neck in stock ITR exhaust (B18C-EJ1)
And then get a high flow cat.....that will be the last bottleneck.
Old Aug 7, 2001 | 11:06 PM
Toda Party's Avatar
Default Re: Bottle neck in stock ITR exhaust (Chris)
thyanks
Old Aug 8, 2001 | 01:18 AM
JDM R98's Avatar
get a high flow cat,or test pipe..run a 2.5" inch custom exhaust piping, and get a stragiht thru free flow muffler like a apexi n1 or the 2.5" outlet/inlet magna flow which i have on mines and love it..and get a good set of headers
Old Aug 8, 2001 | 03:28 AM
Willard's Avatar
https://honda-tech.com/zerothread?id=47625
Old Aug 8, 2001 | 05:25 AM
DutchITR1689's Avatar
Too bad that's not the only bottleneck in a stock exhaust.... 2 more...
Old Aug 8, 2001 | 06:51 AM
SMSP's Avatar
Default Re: Bottle neck in stock ITR exhaust (EuroITR1689)
Really the stock ITR exhaust is good for keeping things quiet but for performance it lacks. There are a total of 3 bottle necks, the tubing diameter varies in 2 or 3 places and the tailpipe is only about 2-1/16" OD! If anyone plans on just going with the standard USDM DC, etc. 4-2-1 or 4-1 and no cams you should upgrade your cat to 2-1/4" and get a good 2-1/4" cat back system, i.e. Magnaflow. If you're more serious and get a JDM (65mm collector) or one of the US Custom built headers with a 2-1/2" collector, cams, etc.. you should be running the 2-1/2" test pipe or cat and 2-1/2" exhaust or you can get by with a 60mm exhaust with the B pipe modified for a smooth transition from the 2-1/2" ID cat outlet to the 60mm (2-3/8") OD cat back tubing.
FYI- I hope to be testing a new hi flow cat assembly in the next month (depends on how much time is lost in moving the shop) in which I'll be shooting for a 20% flow increase over the standard 2-1/2" 94006 Carsound cat. I'm just not sure if folks will be willing to pay for the extra performance to stay legal???
Old Aug 8, 2001 | 07:45 AM
Hooch'n's Avatar
Default Re: Bottle neck in stock ITR exhaust (SMSP)
Yeah, I was shocked when I took my muffler off last week. I could not believe my eyes.
Old Aug 8, 2001 | 09:45 AM
Toda Party's Avatar
Default Re: Bottle neck in stock ITR exhaust (8400-RPM)
sigh, well next thing on my list are spoon 4-2-1s...then i guess i'll have to replace the rest of my exhaust system.
any suggestions? i dont want a loud exhaust that attracts attention...so i was thinking of the mugen twin loop but mugen's frigging$$$$$$$$
[Modified by NBP ITR 01-622, 6:46 PM 8/8/2001]
Old Aug 8, 2001 | 10:50 AM
Hooch'n's Avatar
I almost bought the Twin Loop! I was so close, but I couldn't pay that much money for an exhaut system.
Old Aug 8, 2001 | 07:31 PM
SMSP's Avatar
The Mugen is 60mm and then I believe necks down to approx 2-1/4 for the muffler from what I've read.
Old Aug 8, 2001 | 07:59 PM
xjohnx's Avatar
SMSP - when ya movin so you can start testin out the exhaust system? my r's waitin have you seen the RSR/Skunk one? straight back, 1 bend, under axle system? any input on that?
Old Aug 8, 2001 | 08:07 PM
SMSP's Avatar
Default Re: Bottle neck in stock ITR exhaust (xjohnx)
Does it go under the gas tank? Or does it make 2 bends and go under the area where the stock small resonator is? For a street car I like sticking with the stock location of the tubing.
Trying to move family, house and shop this month. Plus getting some headers out. It's been crazy to say the least.
Old Aug 8, 2001 | 09:38 PM
xjohnx's Avatar
yeah, under the tank, i got apic here somewhere.
http://www.geocities.com/gtssport/parts/rsrexhasut.jpg - copy and paste to see
hangs kinda low, but has to flow well
[Modified by xjohnx, 10:40 PM 8/8/2001]
Old Aug 8, 2001 | 10:02 PM
SMSP's Avatar
Maybe for race but that layout is not for me.
frstwhtgsr2000
Jan 10, 2007 12:01 PM
AllMotor92EG
Aug 3, 2004 07:46 AM
T-roy
Jun 6, 2004 09:52 PM
AllMotorMark
Apr 20, 2004 07:18 PM
csfalcon
Oct 6, 2002 08:21 PM
