help meeee, obd1
ok, I Have a 98 integra LS and I'm supercharging it,
I am going to run a hondata to tune it properly and I need to go to obd1
what would you reccomend
I searched and all I got was a harness kit
I know nothing about this, so any and all help is appreciated
thanks in advance
Nick
thanks in advance
Nick
you'll need the ODB2 to ODB1 adapter that allows you to use the ODB1 ecu. then you'll need to get an ODB1 ecu and either chip it for hondata or send it to hondata to chip for you. while at the same time getting a hondata for your LS ecu and getting it tuned for your setup. hondata only works with ODB1 so you're kinda stuck getting an ODB1 ecu/setup. on the other hand you could go the FMU route but that's not recommended.
you can get one from Skunk...i'm not sure but i think they're the only ones who make it. you'll need to clarify this with other H-T members....and as for the ecu, get a P74 or P75 (94-95 ls) for your application. although you could also use the 92-93 ls ecu as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackThorN »</TD></TR><TR><TD CLASS="quote">ok, I Have a 98 integra LS and I'm supercharging it,
Nick</TD></TR></TABLE>
Nick, I have the harness that you need. You will be able to plug this harness in and be good to to with your OBd2 electronics. You will need to get an OBD1 Ls ecu for your setup. Check my website for more pics of my product and also do a search for me and my reputation. As for the Hondata, you can get that from Vaportrail, KS, and there are many other suppliers on here that sell them.
Your OBD2a to OBD1 conversion harness = click here
Jason
Jason
is there a difference in what ecu I get? seing as i"m going to get a hondata are there any benefits to years of ecu's? and will I still be able to pass emissions with this entire setup?
Or is that pretty much depending on my cat
thanks guys
Nick
thanks guys
Nick
projectef
Jul 25, 2006 03:22 AM
Mr.DC2TurBo
Dec 9, 2003 12:22 PM
, Nick
