Removed Steering Wheel. NEED HELP!
Old Aug 2, 2003 | 11:08 PM
Ryan126's Avatar
Default Removed Steering Wheel. NEED HELP!
Hey Guys, I'm a long time reader of H-T and just got my ITR a few weeks ago. Id post up pix of it but its pure stock and nothing too spectacular yet.
Anyway, I did a serach function regarding this but couldnt find anything so here goes:
I just removed the steering wheel to install a Momo Corse and have encountered some problems.
1. The Airbag light is ON. (How do I turn it off without disabling the Passenger Side Airbag)
2. The Turn Signal does not reset after turning (Does not return to regular position after completing a turn)
3. How do I wire up the horn?
Thanks for all the help and info. Hope to show some pix soon.
-Ryan
I live in Los Angeles, CA. If anyone wants to meet up sometime and go driving in the canyons, PM me.
Old Aug 2, 2003 | 11:39 PM
uNF$@#!'s Avatar
Default Re: Removed Steering Wheel. NEED HELP! (Ryan126)
search, search, and search.
but heres the brief rundown
1) easily
2) of course not
3) carefully
Old Aug 3, 2003 | 06:28 AM
baonest1's Avatar
Default Re: Removed Steering Wheel. NEED HELP! (Soup ****)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soup **** &raquo;</TD></TR><TR><TD CLASS="quote">search, search, and search.
1) easily
2) of course not
3) carefully
Old Aug 3, 2003 | 06:40 AM
len's Avatar
len
I hate elitist ****** that was born with car knowledge. Jesus Harold Christ, it's just a $23,450 car. I could only imagine when they have a slightly more expensive car.
1. Airbag light will stay on. Only way to turn it off is to unplug the harness behind the gauge cluster or remove the bulb. I've heard of some people finding other methods to shut this off. Either way, the passenger airbag won't work properly because the SRS Unit under the dash will go crazy if the Driver's side airbag isn't plugged up. Time to remove the passenger airbag and replace with a CDM one.
2. The hub that you purchased with the steering wheel should have a slot cut into it that controls the turn signal return. Make sure this is there or purchase a hub that was properly designed for your car. You shouldn't have to fabricate anything.
3. There's a thread going on somewhere on this board about this. Supposedly, you can get a Honda Only part and install it to get the horn to work. It's like a Horn "shoe" or something like that. But search on the topic "horn" or something closely related to that. Oh, the steering wheel should come with directions to wire it up. You just need ground and power.
Hope that Helps,
Len
Old Aug 3, 2003 | 11:55 AM
stRtypR25's Avatar
Default Re: Removed Steering Wheel. NEED HELP! (len)
removing the bulb wont do anything, the srs light will still be on.
Old Aug 3, 2003 | 01:37 PM
len's Avatar
len
Default Re: Removed Steering Wheel. NEED HELP! (stRtypR25)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stRtypR25 &raquo;</TD></TR><TR><TD CLASS="quote">removing the bulb wont do anything, the srs light will still be on. </TD></TR></TABLE>
Interesting, mine isn't on anymore. SRS Completely removed.
Old Aug 3, 2003 | 07:19 PM
stRtypR25's Avatar
i dont have a passanger side air bag, and i removed the bulb and the light is still on. did you remove the bulb or unplugged the harness
Old Aug 3, 2003 | 11:28 PM
janet.k2's Avatar
very good information!
Old Aug 4, 2003 | 06:18 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stRtypR25 &raquo;</TD></TR><TR><TD CLASS="quote"> i removed the bulb and the light is still on</TD></TR></TABLE>
lol. lemme get this straight, you removed the bulb, yet it is still on? lmfao.... seriously, you must have removed the wrong bulb. that, or your car is haunted...
csw55
10
Jul 18, 2018 09:54 AM
01em2
Honda Civic (2001 - 2005)
Dec 4, 2008 10:20 PM
dohc_profile
Feb 13, 2008 10:25 PM
99hondacura
Jun 27, 2007 10:39 PM
1phathatch
May 18, 2004 08:32 PM
