comptech header problem....
Old Aug 2, 2003 | 11:12 PM
BrandonClaps's Avatar
New User
Default comptech header problem....
this problem has to do with a civic si, but i'm wondering if i have the wrong header from a type r, or GSR. I tried bolting it up, and it doesn't bolt exactly to the cat like it should. I'm wondering if the header was for a gsr or type r, but was installed on a civic si? I bought it from a friend (can't get ahold of until tomorrow) but i want to be able to sleep better tonight knowing the problem. Look at the picture
Old Aug 2, 2003 | 11:23 PM
ciRcuitJerk's Avatar
jus f0 dekarayshunZ
Default Re: comptech header problem.... (BrandonClaps)
one thread wasnt good enough?
Old Aug 2, 2003 | 11:32 PM
New User
Default Re: comptech header problem.... (ciRcuitSi y0!)
thought the type R guys would know if i needed a type r/gsr cat
Old Aug 3, 2003 | 09:04 AM
RaIn's Avatar
I have a flange made to fit that, along with a o2 bung already in it.
Old Aug 3, 2003 | 09:17 AM
Tweakmeister's Avatar
Default Re: comptech header problem.... (RaIn)
looks like a little flexpipe would be the easiest way to fix your problem.
Old Aug 3, 2003 | 10:31 AM
Padawan's Avatar
Darth ModerVader
From this angle it looks like the length is fine, it's just the position of the flange that's the problem. It appears to be an ITR/LS or '00/'01 GS-R header, which is the same length as the Si's but with a different flange angle.
Old Aug 3, 2003 | 01:41 PM
New User
Default Re: comptech header problem.... (Padawan)
well that is the problem. I actually got a universal flange from autozone for a temp solution to drive the car. The header is actually shorter then stock so it must be for an integra. Now my whole exhaust is pushed forward and the tip instead of it being flush with the rear lip, it's in like 4-5 inches. Is there a test pipe that i can purchase that would be the correct size that would push the exhaust back to where its supposed to be? I could probably have one made, but if i could purchase one with an o2 bung that would be better.
Old Aug 3, 2003 | 01:51 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrandonClaps &raquo;</TD></TR><TR><TD CLASS="quote">]Now my whole exhaust is pushed forward and the tip instead of it being flush with the rear lip, it's in like 4-5 inches.</TD></TR></TABLE>
Then I misjudged from the picture, and it isn't an LS/ITR or '00+ GS-R.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrandonClaps &raquo;</TD></TR><TR><TD CLASS="quote">Is there a test pipe that i can purchase that would be the correct size that would push the exhaust back to where its supposed to be? I could probably have one made, but if i could purchase one with an o2 bung that would be better.</TD></TR></TABLE>
You can get a testpipe in any size you want, although the ECU will still throw a code whether there is a O2 bung in it or not. I would personally go with a 2.25" Carsound cat. for this application.
Old Aug 3, 2003 | 02:12 PM
New User
i don't think you misjudged. but it's shorter then the stock si one. so everything is pushed forward. So why would i have an o2 bung if it wont stop the cel? Do i need to get an o2 simulator? Test pipe in any length? Custom or purchased off the net? Any links would be appreciated.
Old Aug 3, 2003 | 02:22 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrandonClaps &raquo;</TD></TR><TR><TD CLASS="quote">So why would i have an o2 bung if it wont stop the cel?</TD></TR></TABLE>
That was my point. You might have luck with an O2 simulator or the foil trick, although I've never tried either of these. Dave at SMSP should be able to make you any testpipe or Carsound cat. that you need. Give him a call - he's always very helpful and his work is excellent.
Old Aug 3, 2003 | 09:50 PM
New User
SMSP? Link/phone number? I need something quick what i have now is just a temporary solution. How will i know how long i need it?
Old Aug 4, 2003 | 08:10 AM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">David Stadulis, Owner
SMS Products
4755 Ewell Rd.
Fredericksburg, VA 22408
NEW Email: smsproducts@adelphia.net
SMS Products Headers - Because diameter and length do make a difference
When you always tell the truth you'll never have to "remember" what you said.
One never knows the truth unless he seek it out.
540-287-6384
http://www.sms-products.com coming....</TD></TR></TABLE>
Dave may know the length you need off-hand, or you could simply measure it.
bb608901
Apr 4, 2007 11:48 AM
TommyTom83
Aug 28, 2004 10:24 AM
S2KILLA
May 31, 2004 09:24 PM
B18CYAAA
Aug 23, 2003 12:44 PM
