Can alternator go bad practically overnight ~ (after a motor swap)?
Old Aug 2, 2003 | 08:59 PM
5 Skware's Avatar
I missed the boat
Default Can alternator go bad practically overnight ~ (after a motor swap)?
Hey guys I just finished my OBD1 B16 swap into my 2000 civic hatch, I swapped the OBD2 alternator (which had seemingly been working great before) onto the B16 and it seems to have bit the dust!
I tested it by removing the negative battery cable while the motor was running and it instantly cut out. So my question is; does this sound right? Is it possible (or likely) that my 3 year old alternator just went out conviently after the swap?
Any help is greatly appreciated.......I wanna drive this thing
Old Aug 2, 2003 | 09:30 PM
salbaje's Avatar
Default Re: Can alternator go bad practically overnight ~ (after a motor swap)? (EGCIV)
Cant really tell when they will go out. How long did you have the motor sitting??
Old Aug 2, 2003 | 09:41 PM
5 Skware's Avatar
I missed the boat
Default Re: Can alternator go bad practically overnight ~ (salbaje)
I was running this alternator on my D16 just last week without any noticable problems. Thats what seems so weird
Old Aug 2, 2003 | 09:45 PM
GZERO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGCIV &raquo;</TD></TR><TR><TD CLASS="quote">
Any help is greatly appreciated.......I wanna drive this thing </TD></TR></TABLE>
Yes, it sounds right, when you lift the negative battery cable, newer cars turn off. Never do that again, the load on your electrical systems is hard to take and some things can get damaged.
If you want to try your alternator get a voltmeter and put it on the battery terminals and turn the car on, turn every electrical device on your car on as well (stereo, lights, hazzard lights, etc..) and it should read above 13 volts at idle, and if you accelerate the car it should come close to 14V, if every electrical device is off the car should read 14.4V altough is not that important to be 14.4V exact. if you turn everything on as i stated before and the voltmeter reads more than 13 V you're ok.
Old Aug 3, 2003 | 03:50 AM
deepnite's Avatar
Default Re: Can alternator go bad practically overnight ~ (GZERO)
ive had 3 go out on my truck without any warning at all..in ur case id suspect its a wiring issue since the alternator was working befor the swap
Old Aug 3, 2003 | 07:56 PM
5 Skware's Avatar
I missed the boat
Default Re: Can alternator go bad practically overnight ~ (deepnite)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deepnite &raquo;</TD></TR><TR><TD CLASS="quote">in ur case id suspect its a wiring issue since the alternator was working befor the swap</TD></TR></TABLE>
I was thinking the same thing only thing is I am using the same harness from my old motor and the plug is good as well as the ground on the alternator
So is there anything else that I should check before just getting a new one? Is there a definite way to check whether it is a wiring issue or a problem with the alternator itself?
Thnaks again for the help and suggestions
Old Aug 4, 2003 | 12:31 AM
r1emperor's Avatar
Take the alternator off and have it tested. Many auto parts stores will test it for you.
DC206R
Apr 24, 2009 09:32 AM
h2point2
Mar 4, 2008 02:52 PM
slickchick
Nov 8, 2006 09:29 AM
5 Skware
Aug 4, 2003 04:18 PM
racecarpete
May 28, 2002 08:22 PM
