Alternator question. Swap related.
hi, guys when you do a swap do you use the civic alternator or the one that is supposed to go with the engine you are getting? Reason is i want to get a lude swap but have a upgraded alternator for competition and need to keep this alternator. Is this possible?? Also my aftermarket alternator does NOT plug into the stock harness it is run by a separate regulator. Let me know. thanks...
Re: Alternator question. Swap related. (SilverCivic2k)
Shawn
not sure about D to H series...
but the mounting points on the D-series differs from the B series.
Try holding them side-by-side
Are running the new alt. right now with the sohc? You can probably wire it up no problem, but I don't know if the belt or the mounting brackets will work.
Re: Alternator question. Swap related. (97hb)
alright thanks guys yeah the alternator is on my car now so when i get a swap it would have to go on with the new engine. To get this alternator they had to modify my stock bracket to fit anyways so i guess a little more modification is expected.
