vibration problem please read
Old Aug 2, 2003 | 07:59 PM
1stealthls's Avatar
Default vibration problem please read
i have a 90 crx w/b16a
i replaced the axle cuz the boot was torn and started makin some noises
well after i did that i had a major shaking with the left front(side i replaced)
so i figured auto zone gave me a junk one well 4 axles later same problem .....i have checked everything .......would the intermidate shaft cause this also it only does it when i turn right or get on it hard.....i have had the wheel off to check where it is comin from still stumped .......could it be somethin w/ the tranny?????or do i have to take the snap ring off of the axle or what????this is getting real stressfull i need it fixed by monday........i checked everything ...brakes....wheel bearing....ball joints....tie rod ends.....please help any suggestions would be great
thanx ahead of time
Old Aug 3, 2003 | 07:40 AM
1stealthls's Avatar
Default Re: vibration problem please read (1stealthls)
please help me out
Old Aug 3, 2003 | 06:44 PM
CanuckCRX's Avatar
New User
What axle did you buy??
Are you using the intermediate shaft that came with your swap?
Old Aug 4, 2003 | 09:43 PM
CanuckCRX's Avatar
New User
Default Re: vibration problem please read (CanuckCRX)
Hello???
Old Aug 6, 2003 | 11:17 PM
CanuckCRX's Avatar
New User
Ok fine, I won't help you
Old Aug 6, 2003 | 11:24 PM
mmuller's Avatar
Mad Scientist
dude the guy is offline...
Old Aug 8, 2003 | 12:20 PM
CanuckCRX's Avatar
New User
Default Re: vibration problem please read (mmuller)
For 4 days??LOL
Old Aug 8, 2003 | 12:48 PM
irev210's Avatar
my guess is when u took the ball joint off to replace the axle, you totally fucked ur allignment (toe/caster) causing ur car to vibrate because ur wheel isnt rolling straight.
Your allignment is way off... go get an allignment...
atleast thats what I think, any other opinions?
Old Aug 8, 2003 | 06:30 PM
CanuckCRX's Avatar
New User
Need to know axle shaft/intermediate shaft combination you are using...
crxgsrsi
20
Dec 16, 2013 11:09 AM
B16-CRX
Aug 5, 2009 09:16 AM
jdm94accord
Jan 11, 2007 07:22 AM
1stealthls
Aug 3, 2003 09:44 PM
SyN37
Mar 18, 2003 06:47 PM
